b16a2 into eg question
Old Oct 9, 2009 | 09:58 PM
jamelin's Avatar
Default b16a2 into eg question
ok im gonna pick up a b16 swap for my 94 eg hatch shell and i had a quick question, since its an obd2 motor and the car is obd1 will everything just plug and play? or do i need a jumper harness? just wanna make sure so i dont run into problems.
Old Oct 9, 2009 | 10:03 PM
roycivic92's Avatar
Default Re: b16a2 into eg question
jumper harnest needed
Old Oct 9, 2009 | 10:08 PM
Ya Digg's Avatar
u could get a gsr engine harness that is obd2 and it will be plug and play. and wire vtec from the shock tower harness to the ecu.
or wire the stock eg harness so its obd2. and wire vtec
u will need a obd1 b16 ecu or and ecu with b16 specs.
no jumper harness that's if u were to use the and obd1 ecu in an obd0 or obd2 car.
Old Oct 9, 2009 | 10:10 PM
roycivic92's Avatar
the car will run better on obd1 better tunning options(hondata).
Old Oct 9, 2009 | 10:16 PM
98civdx's Avatar
Master Detailer
you could also just run obd1 integra dizzy and things on it, and just run the stock harness, and wire in vtec and what ever else
Old Oct 10, 2009 | 05:38 AM
jamelin's Avatar
so to make the motor obd1 i can use the obd2 wiring harness with a obd1 ecu? i didnt plan on messin with the obd2 b16 but im getting it pretty cheap so i guess its a chance to learn something new.
Old Oct 10, 2009 | 02:45 PM
JohnnyWash1's Avatar
I did this exact swap. I pulled the harness off my B18B1 (which was OBD2) and used that. It worked perfectly.
Old Oct 10, 2009 | 04:53 PM
CivicSpoon's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/1-8-dohc-vtec-550976/ 6th post down.
Ryan bud
Dec 12, 2012 01:09 PM
trevek10
Sep 17, 2009 05:28 PM
2wheelhunter
Jun 4, 2007 04:18 PM
97DGreenEx
Oct 13, 2006 06:21 PM
screen_name
Apr 22, 2006 06:56 PM
