NO OIL HELP.
I have been running my car with no oil un-noticed becuase the oil light dos not work im guessing, my question is what can happen to a motor running with little or no oil?? and i have been running the car with no oil for 2-3 weeks off and on. the cuplret is my oil line to the oil pan from turbo.
what can or might have happen to my motor. running no oil.
well motor still strong turbo still workin and booste i think i cought it in time, there was oil still leaking thats y i checked and it still shows up on the dip stick so i might have lucked ut, but thanks i fixed the leak and im fillin that bad b@#tH up again.
thanks , and what would the car and turbo feel/ look like if that happened?? just in case. i can look for symptoms.
its v-tec but the v-tec never worked ever since i had the car and i have done oil changes on it, but not after i got my new set-up installed, and the return line was leaking and thats when i found out no oil.
I came into this problem today too.
Every time I would do a turn onto another street the oil light would blink. So I got home and had no oil, the dipstick didn't show any at ALL.
What could make my motor burn up so much oil all of a sudden?
I'm not trying to thread Jack OP, looks like were on the same boat.
well thats another problem itself, just FYI oil needs to be full for VTEC to work , as with other variables
well if yur motor sounds like this its ****ed http://www.youtube.com/watch?v=1ZBbKMaOlK0 when it comes to no oil, its either the engines ****ed or running
my light never flashed ever, but yes when i park i see spots but i fixed the problem and filled her up , i think my problems over but whats up with yours, let try to help her out.
but my motor only has like 7,000 on it and i dont feel any funny stuff from it just smooth other then the leak i had but shes good now and i change my oil like i should.
I'd say I have 80K on the engine. Never seen any oil spots, Im going to be keeping a close eye on it from now on.
I read it somewhere, where the dealer drain the oil off a acura RL (trade in Chunker car), and drove the sucker for 40 mins. Then it finally caught on fire at the back.
But the first thing it'll go out is your valvetrain then your rods.
Acura_I-RS
Jul 26, 2003 11:13 AM
