flywheel bolt thread pattern
Old Oct 9, 2009 | 01:25 PM
jweeks's Avatar
Icon2 flywheel bolt thread pattern
ok ive got a ef civic with a zc swap i bought the motor with the tranny already on it and someone didnt put it together right because all the bolts that hold the flywheel on striped out and wore the holes out on the crank. i was wondering what the pattern was for the bolts that hold the fly on, i wanted to fix it with a heli coil and the local parts stores can figure out the thread, i was just going to order some online.
Old Oct 9, 2009 | 01:47 PM
88Hatchy's Avatar
Default Re: flywheel bolt thread pattern
haha. It's over. Get your money back
Old Oct 9, 2009 | 02:26 PM
KWayRacing's Avatar
Why not drill and tap new threads, new Grade 8-10 bolts and red loctite and and long sincere prayer and maybe it might hold.
Old Oct 9, 2009 | 02:42 PM
jweeks's Avatar
well i want to use the 12 point bolts i got because they have short heads and they're the right size for the flywheel, and i know they're strong. i just need to know the pitch of the thread so i can get the right heli coil and then drill it and tap it.
Old Oct 9, 2009 | 03:16 PM
4drEF's Avatar
Keyboard Humorist
Originally Posted by jweeks
... the bolts that hold the flywheel on striped out and wore the holes out on the crank.
Crank is trashed?
OUCH.
Old Oct 9, 2009 | 03:25 PM
jweeks's Avatar
not trashed heli coil will fix just need to know the thread!
Old Oct 9, 2009 | 03:58 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Try 12mm X 1.0mm pitch..
Old Oct 9, 2009 | 04:26 PM
jweeks's Avatar
I'll try thanks
Old Oct 9, 2009 | 04:46 PM
88DXCRX's Avatar
PS that is an oddball size from what I can tell..
I don't see anyone offering that exact pitch so you might have to
go to a different one..
As far as thread repair goes..Also look into "EZ-lock" or the one
I am familiar with "time-serts"
link: http://timesert.com/
Old Oct 9, 2009 | 04:55 PM
EJ1_Sleeper's Avatar
i would never trust something like that on crank man. just get your money back, or swap the crank for a good one.
Old Oct 14, 2009 | 12:13 PM
jweeks's Avatar
anyone got a crank forsale, ive tried every parts store the repair shop in my town and no one can find anything for that thread. what all cranks can I use for the dohc zc?
Old Oct 14, 2009 | 12:15 PM
D16SiHatch's Avatar
i believe any d16 crank from 88 to 00 will work.
Old Oct 14, 2009 | 12:20 PM
torino_red_crx's Avatar
some zcs use different size pulley snouts.
try thezcr.com to find a crank, thats your best bet
Old Oct 14, 2009 | 12:53 PM
jweeks's Avatar
someone's gotta know that pitch
Old Oct 14, 2009 | 03:05 PM
88Hatchy's Avatar
Old Oct 15, 2009 | 09:11 AM
12mm x 1.00 RH
per:
http://www.summitracing.com/parts/ARP-208-2801/
for a 91 CRX since all D series use the same size flywheel.
Old Oct 15, 2009 | 09:13 AM
Originally Posted by torino_red_crx
12mm x 1.00 RH
per:
also try searching google for that tap size, i saw a couple one there, its probably not a common size, thats why local stores dont have it.
eh2_Trav
Transmission & Drivetrain
Nov 4, 2016 08:47 AM
c0d0r
Mar 29, 2009 02:22 PM
dremmel
10
May 4, 2005 12:27 AM
MisterB
Sep 10, 2003 11:24 PM
Specialk
May 21, 2003 02:14 PM
