Transmission & Drivetrain Gearboxes, Differentials, Clutches
Rebuilt trans making noise
Old Oct 9, 2009 | 05:56 AM
Jspec_ej8's Avatar
Default Rebuilt trans making noise
I just had my b16 transmission rebuilt..type R lsd mfactory 4.9 diff ls fith carbon coated synchros and brand new bearings and seals..the problem im having is when the trany is coasting in gear i hear a bad whining noise it gets a little quieter when i put it in neutrol.. If anybody could help me out i would really apriciate it... Thanks
Old Oct 9, 2009 | 07:48 AM
Honda Bull's Avatar
Default Re: Rebuilt trans making noise
Probably bearing noise. Either one not installed the 'correct' side up, or a bad needle bearing that perhaps was damaged prior or got damaged in the process.
Old Oct 9, 2009 | 10:06 AM
Aquafina's Avatar
Could also be the FD (would be a real quiet whine). Semi-helical gears will whine whereas stock helical gears will not.
Old Oct 9, 2009 | 11:48 AM
Jspec_ej8's Avatar
Thanks.. Will check them when i take it apart
Old Oct 9, 2009 | 11:55 AM
Jspec_ej8's Avatar
Yea i was leaning towards that but I spoke with an mfactory rep and he said that they really dont make noise that they are really quiet on hondas trannys
Old Oct 9, 2009 | 07:12 PM
MFactory's Avatar
Usually the tranny fluid drowns out most of the sound, but you will still hear a small whine compared to the oem (which doesn't really whine at all).
Old Oct 9, 2009 | 07:28 PM
Aquafina's Avatar
I can hear the whine with my MFactory close gear set, even over the SMSP race exhaust (only on light throttle). In cars with full exhaust and close gear set it was easy to hear the whine.
Old Oct 10, 2009 | 04:17 PM
Jspec_ej8's Avatar
Ill probably take it apart to be sure that theres nothing wrong i have built a couple of b-series transmission and never had a problem...this is my first time using a non oem fd..thats why im in dout
2kdrift
Dec 3, 2010 09:14 PM
Rooftop voter
Nov 3, 2010 06:11 PM
Mr. Em1
Oct 8, 2007 11:47 AM
Nicknyce
Jan 16, 2005 10:20 PM
