need help big time
Old Oct 8, 2009 | 06:43 PM
trav39562's Avatar
Default need help big time
I finally got my car running and Im getting these codes now. I have looked at the codes on this site and the net. I know the codes just dont know how to fix it any help would be great. The first code is p1297 electric load detector circuit low voltage. p1337 engine speed(RPM) fluctuation sensor no signal/ csf sensor no signal.p0453 fuel tank pressure (ftp) sensor high voltage. and p0450 is pending evap emission control system pressure sensor fault. Thats alot of problems. please help
Old Oct 8, 2009 | 08:07 PM
mortificationrock's Avatar
Default Re: need help big time
We need more details....what make,model,year, engine you running etc.
Please help us....help you.
Old Oct 8, 2009 | 08:10 PM
Former User's Avatar
Check whether 7.5A fuse 15 under the dash is blown.
Old Oct 9, 2009 | 08:27 AM
trav39562's Avatar
its a 2000 civic ex with a d16y7 block and y8 head. all stock now exept for the 255 walbro fuel pump and a fpr thats still hooked up. I checked that fuse and it was blown. I replaced it and took both + and the - battery terminals and left it for about 30 minutes and then I cranked it I am still getting those codes.
Old Oct 9, 2009 | 08:32 AM
Check whether fuse 15 blew again. If so, this TSB describes the possible cause and fix.
Old Oct 9, 2009 | 09:07 AM
trav39562's Avatar
the fuse is still good.
Old Oct 9, 2009 | 11:13 AM
Does the engine run?
Remove the 7.5A Back Up fuse under the hood for 10 minutes to clear the codes. Then drive the car and post CEL codes that are thrown.
Check whether the CKF sensor is unplugged or whether the wires are damaged. Also check whether any EVAP system vacuum hoses are disconnected or leaking.
Old Oct 9, 2009 | 12:29 PM
trav39562's Avatar
yeah the engine runs but its real sluggish its running rich there is black carbon soot on the plugs. I checked the back up fuse under the hood it was blown so i replaced it and checked again still the same codes so i pulled the fuse back out and I erased the codes using my code reader. I cranked it back up and the 1297 and the 1337 code came back.
Old Oct 9, 2009 | 01:13 PM
Why do you have so many blown fuses?
Do you have a 3-wire or 4-wire alternator? Is the AltC wire cut?
Does your hood fuse box have an ELD?
Is the CKF sensor unplugged?
Old Oct 9, 2009 | 04:18 PM
trav39562's Avatar
its a three wire alt and i dont see any cut wires I know I didnt cut any. ( Does your hood fuse box have an ELD? ) what is an ELD? The ckf is plugged but it looks like the timing velt may be hitting the sensor. It has a mark on it about the same size as the metal part on the sensor. Im gonna pull the crank pulley of tommorow and look at it.
Old Oct 9, 2009 | 06:02 PM
Your USDM ECU looks for an ELD in the hood fuse and must be matched with a 4-wire USDM alternator rather than a 3-wire Canada alternator.
Sounds like the CKF sensor wires are damaged.
Old Nov 7, 2009 | 02:54 PM
trav39562's Avatar
ok heres the update. I got the p1297 code to go away. I replaced the ELM and that did it. I put a new ckf sensor on hoping it would eliminate the p1337 code but it didnt. I still have the other two codes on as well. The p0453 and p0450 pending. Any ideas
Old Nov 7, 2009 | 04:58 PM
trav39562's Avatar
i just checked the plug to the ckf sensor and theres no voltage and no voltage at the computer. Dont know whats up
jrami020
Oct 18, 2009 02:24 PM
suzuki1211
Dec 30, 2008 11:33 AM
-JSpecEk*9-
May 2, 2006 11:28 AM
_Bug_
13
Feb 22, 2006 07:30 AM
bgod
Jun 5, 2003 09:50 AM
