Rev limit issues
Old Oct 8, 2009 | 04:00 PM
1995honda's Avatar
Default Rev limit issues
Hey guys i have a 95 civic hatch i swapped a b16 a while ago and just recenty decided i wanted to rev it to 8k and i found it won't rev past 6900... thought it was the ecu, but swapped out multiple ecu's and chips that i am positive they are good and still 6900. searched last night thought maybe it was the dizzy so i tried my friends tonight and still the same thing. i'm out of ideas and can't find anything. the car was never revved that far before cuz is had a sohc in it so anyone with any ideas please help me out thanks.
Old Oct 8, 2009 | 04:09 PM
Emorales's Avatar
Default Re: Rev limit issues
What programn u running
Old Oct 8, 2009 | 04:35 PM
1995honda's Avatar
chipped p28... tried the ecu in my buddies car and revved to 8k like its chipped for, threw it back into mine and 6900... phearable chip.
Old Oct 8, 2009 | 04:55 PM
Emorales's Avatar
Could be chipped but when it gets tunned they can disable things as well addIng features like 2 step and etc ur buddies ecu might have complete diff set up... Not100%
Old Oct 8, 2009 | 05:37 PM
1995honda's Avatar
my friend has a bone stock b16 just like mine i tried his chipped ecu, my chipped ecu and a p30 in his car they all rev around 8k but when i put those same ecus in my car they hit rev limit at 6900
Old Oct 8, 2009 | 06:16 PM
1995honda's Avatar
has anyone else had this problem?
Old Oct 9, 2009 | 08:52 AM
1995honda's Avatar
ANYONE???
Old Oct 9, 2009 | 09:02 AM
roycivic92's Avatar
naw man u think ur tach is miss reading
Old Oct 9, 2009 | 05:56 PM
1995honda's Avatar
i thought so too so i wired an auto meter tach in and its reading the same as my tach in the cluster, i checked every sensor and they all have the correct voltage going to them
Old Oct 9, 2009 | 06:27 PM
SergEK's Avatar
Your car is trying to save you from going too fast
Check -Fuel/Spark/Air
Filter/dizzy/fuel pump/injectors
Somewhere something is holding you back
Old Oct 10, 2009 | 02:50 PM
1995honda's Avatar
tried new dizzy, fuel filter is 2 weeks old and i have the proper fuel pressure just checked today
Old Oct 10, 2009 | 02:55 PM
93egSLEEPER's Avatar
are you getting any CELs?
Old Oct 10, 2009 | 03:07 PM
1995honda's Avatar
nope there is no cels thats why im so confused
Old Oct 10, 2009 | 03:19 PM
is vtec engaging? it almost sounds like fuel cut from the injectors like it will do to a boosted car with a bad fuel pump.... but your not boosted.
Old Oct 10, 2009 | 03:24 PM
1995honda's Avatar
vtec is engaging, the car is n/a but whats weird is it has the correct fuel presure
Old Oct 10, 2009 | 03:33 PM
huh.... only other thing i can thing of is the VSS is acting up and making your tach and ecu read different things causing a rev limit.
Old Oct 10, 2009 | 03:40 PM
1995honda's Avatar
it has the correct voltage running to it ill swap mine with my buddys and give it a shot thanks man ill let u know if it works
Old Oct 10, 2009 | 04:19 PM
slow96lude's Avatar
are you sure the fuel pressure was there when you were reving to 6900. It may be your pump not supplying enough when you get it up that high and its cutting out
Old Oct 22, 2009 | 04:01 PM
1995honda's Avatar
it was the tps sensor i put a new one on and everything is all good thanks for the ideas guys
stiffymeister28
Jun 10, 2011 08:22 AM
masijdm
19
Jun 11, 2009 09:11 PM
SpdKilz23
Sep 28, 2008 08:51 AM
Aespooncivic
Mar 5, 2005 07:54 PM
Turbocoupe97
Aug 15, 2004 11:19 AM
