Hesitation in low rpm and hard starting when cold
Old Oct 8, 2009 | 06:28 AM
Sherm's Avatar
Default Hesitation in low rpm and hard starting when cold
Just did a headgasket job on a 1994 civic w/ a d15b7. Idle is fine, but if you just tap the throttle for a quick rev it stumbles for a second, then revs fine. If you ease into the throttle its much smoother and once it builds some RPM's it seems to have normal power.
Also, it has an issue starting when the motor has been sitting overnight. I have to crank it with giving it gas for atleast 5 or more seconds...it starts, kind of stumbles, then idles normally. When warm, it fires up very quickly without hesitation. Its throwing code #6 for the ECT sensor...the plug that goes to the sensor in the head is damaged so I know the source of the code. Could the code be related to either of my problems? Any input on where to start would be helpful.
Last edited by Sherm; Oct 8, 2009 at 06:30 AM. Reason: please move to 1992-2000 civic forum!
Old Oct 8, 2009 | 06:45 AM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Hesitation in low rpm and hard starting when cold
The ECT will most definitely give you problems when cold. Change it.
BTW this is the Accord forum.
Old Oct 8, 2009 | 08:02 AM
Sherm's Avatar
Thanks....lol I know...didn't notice that I posted in the wrong forum until I was already done. Its been reposted in the civic section.
JDM_Certified
Jun 30, 2009 08:47 AM
jdmkid_82
Oct 31, 2008 12:11 AM
1337 Si
Oct 2, 2008 01:59 PM
rtpassini
Jun 27, 2004 02:42 PM
