Front driver side camber won't adjust correctly
Old Oct 7, 2009 | 07:33 AM
joelmatt89's Avatar
Default Front driver side camber won't adjust correctly
So I got a new set of tires and rims for my car and after putting them on I lowered it a little. I had it all the way up before with the 17" rims the po had on there which rode like hell even lifted up all the way. It rides greatwith the 15s and i lowered it all the way around to the exact same height from the wheel well to the ground, about a finger and a half from tire to wheel well, so it's not really slammed or anything.
I can get the camber on the passenger side to be 0 and a little positive if i want but the driver side will not go to 0 i adjusted the camber as far as it will go and it's still negative. I don't have the correct tool so i use a weighted string to give me a vertical line and measure off that. From the lip on the rim the top is 1 cm farther in than the bottom. It doesn't make sense why the car can be the same height on both sides but the camber isn't the same on both sides, i was just wondering if anyone has had this problem and knows how to correct it. The camber kit on there is the skunk2 kit so it's not like it's ebay crap or anything.
Old Oct 7, 2009 | 01:55 PM
joelmatt89's Avatar
Default Re: Front driver side camber won't adjust correctly
bueller
killercrx91
Mar 16, 2009 04:23 AM
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
qazaq
Feb 20, 2007 09:50 PM
Boost2NA
Nov 13, 2004 03:10 PM
ALF
Aug 16, 2001 05:47 PM
