alignment ?
Old Feb 19, 2007 | 02:45 PM
qazaq's Avatar
Default alignment ?
just got an alignment done and people in shop convincing me that they can not adjust my camber because my car is lowered. they only adjusted the toe. after they returned my car to me first thing they told me i have no camber adjustment kit on my car but i have skunk2 pro kit front and back. after i said i do have it then the mechanic changed his topic and start saying that he can not do it for a different reason because my tire will touch the fender on the bumps if he adjust the camber
sounds like bs to me, plus visually there is like 2" clearance fom tire to the fender side
is this true or they just too lazy to mess with adjusting the camber kit bcause i no it's a pain in ***
Old Feb 19, 2007 | 02:48 PM
Pee Wee's Avatar
Default Re: alignment ? (qazaq)
they should just adjust it and if the tire rubs it your fault. and if you have that much of a gap, why do you even have a camber kit?
Old Feb 19, 2007 | 02:50 PM
qazaq's Avatar
Default Re: alignment ? (Pee Wee)
2" gap because the camber is negative and wheel is tilted inward.
Old Feb 19, 2007 | 02:53 PM
Pee Wee's Avatar
how bad was the camber. I just dont see how your camber could be that bad when you have a 2" gap. toe is what will cause excessive wear anyways
Old Feb 20, 2007 | 09:50 PM
RaceCarRyne's Avatar
i use to work in an alignment shop and that is a lame excuse for lazyness
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
The Si
Suspension & Brakes
Feb 5, 2007 09:03 PM
KraZyCHOWMEIN
Dec 19, 2001 07:58 PM
PorscheGT2
Dec 4, 2001 07:37 AM
ALF
Aug 16, 2001 05:47 PM
