*No sound coming from my head unit.*
Old Oct 7, 2009 | 12:29 AM
Fantastic420's Avatar
Default *No sound coming from my head unit.*
I had a cd player hooked up without a chassi harness to connect to cd player harness to the head unit. I bought a chassi harness and cd player/head unit harness. I connected my TV head unit and I got no sound but I see the tracks going. Blown speakers or wiring problem? I did the wiring right, and I don't think I blew my speakers like that because they were just working a few hours earlier that day. If anyone would help by knowing what could be wrong, that'd be great. Thanks
Old Oct 7, 2009 | 12:32 AM
del sol noob's Avatar
Default Re: NEED HELP, no sound just plays.
maybe crossed speaker wires ?
Old Oct 7, 2009 | 12:33 AM
All wires that are connected and disconnected are taped from touching what isn't needed but thanks.
Old Oct 7, 2009 | 12:53 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: *No sound coming from my head unit.*
Are you sure the new radio works? Is it used? It could have blow outputs on the internal amp. If you are sure that everything work it has to be in the install
Old Oct 7, 2009 | 04:25 AM
jason0123's Avatar
if you have an old or extra speaker. Try hooking it up directly to the deck to make sure it works. And then go from there. Also what kind of deck is it. Some of them you can shut the internal amp off.
Old Oct 7, 2009 | 09:04 AM
Might be because I know the speakers work, don't think they're blown.
It's a Pioneer AVH-P5000 flip out, nearly mint. All 4 speakers worked earlier that day. Where can I check to turn off/on? If it don't work, probably the install as stated. Thanks
Old Oct 7, 2009 | 12:59 PM
Bump! I need help, I need music in the car. I tried hooking up a different working speaker directly to head unit, no sound either. I also tried a different head unit, no sound. Maybe it's the wiring from chassi harness? I checked that and all was correct. Any suggestions?
Old Oct 7, 2009 | 01:14 PM
have you checked the fuses
Old Oct 7, 2009 | 04:23 PM
mrdeadman's Avatar
They let me pick
Is your head unit even powering on?
If you tried two different hus and both don't work I can almost guarantee you screwed up the wiring or your fuse is blown.
Old Oct 7, 2009 | 10:48 PM
Ya, it runs on and plays but no sound. I just found out my audio is messed up. Shi*s garbage or I get it fixed. S'all good, thanks
Old Oct 7, 2009 | 10:58 PM
Can you bench text this? Use the head unit and not a aftermarket amp.
DCFerris
Audio / Security / Video
Apr 13, 2009 06:54 PM
Dirtfall
Jul 1, 2006 03:08 AM
dylokjai
Mar 22, 2005 02:01 PM
hometheaterman
Oct 30, 2004 07:02 PM
JDMCRVTEC
Jun 27, 2002 09:25 AM
