H22a civic headlight clearence
I just recently bought the black housing headlights from eBay, and tried purring in the drivers side headlight and it did not fit because of the h22a alternator. The housing/mount for the headlight is a little fatter than the stock headlight and it touches the alternator and belt. My dad says I can adjust the alternator to make it sit a little lower so the new headlight will barely fit. He said all I need to do is move the alternator down a little and get new alternator belt. Is he correct? Or am I going to have to sell these new headlights and put my stock headlights back on?
http://www.swapshopracing.com/contents/en-us/d696.html
^^there are also alternator relocation brackets available. ^^
i had the same problem with my swap...so what i did was a combination of both lower the alternator has much has i can and the cut a lilttle bit off the headlight it wont effect anything on your headlight and left a gap enough for it to clear....
slow_rex_will
May 21, 2005 01:04 PM
shauniewalnuts
Mar 8, 2003 02:18 PM
