Speedo Problems
Old Oct 6, 2009 | 07:55 PM
puSSy's Avatar
Default Speedo Problems
Well I just picked up a 1995 accord v6 auto, and the speedometer doesn't work. Every other gauge works. It has an abs light that comes on every once in a while too. The cruise doesn't work either, but before I just replace it I wanted to get some other input from you guys. Thanks
Old Oct 7, 2009 | 08:30 AM
213374U's Avatar
0x5359-0055
Community Builder
Default Re: Speedo Problems
VERY common problem with this year model. I had to replace mine. Not much else you can do.
Old Oct 7, 2009 | 09:06 AM
billyrusa's Avatar
If the both speedometer and cruise do not work, it is possible a bad vehicle speed sensor. Eventually, you may have a TCM code 4 complaining VSS.
Old Oct 11, 2009 | 09:15 AM
puSSy's Avatar
Yeah I haven't had a check engine light though. How long does it usually take to throw one? Also now sometimes my tach doesn't work. And it gets slow. Thats only every once in a while and it usually goes away when you warm it up.
Old Oct 11, 2009 | 09:51 AM
YeuEmMaiMai's Avatar
VSS may not thorw a code until it really gets wacky.......so remove it and clean it and reassemble it and reinstall it. There is a VSS cleaning guide on the internet
Old Oct 11, 2009 | 06:13 PM
puSSy's Avatar
Can you find the write up on that? Also every once in a while the speedo works. Maybe once or twice a week.
Old Oct 11, 2009 | 06:27 PM
P_Adams's Avatar
What? You don't know how to do a google search? I'm quite sure that YeuEmMaiMai would have been more than glad to supply it if he had it available (He's really quite helpful, you know) But obviously.....
I didn't know he offered a research service
Personally, I haven't seen what he was refering to. I'd suggest just go out and pick up a new one. The VSS is one of the cheaper sensors used by Honda.
P
Old Oct 13, 2009 | 04:58 AM
puSSy's Avatar
Is their a how to on putting it in? Because I've never done it before.
Eric Revell
Feb 17, 2018 10:19 AM
Tank_EM2
Honda Civic (2001 - 2005)
Jul 1, 2014 03:28 PM
TMaccord91
Oct 6, 2004 09:30 PM
