2003 Honda Odyssey remote start/alarm install help
Old Oct 5, 2009 | 03:18 PM
laziebun's Avatar
Default 2003 Honda Odyssey remote start/alarm install help
I dont know why im having such a hard time with this install but its kicking my ***.
I have a 2003 Honda Odyssey EX. First problem im having is i can not find the DAMN lock and unlock wire( Green/red and Black/wht ) . This is what i've done to try to find it......
I took the door lock at the door panel off to make sure im looking for the right color wires, and sure enough it is. I then follow the loom from the door to the fender and then to the inside of the cab. I put one lead of the fluke to the green/red wire and then with the other lead i prob ever wire off the loom coming in from the fender and NO damn continuity AT all. I check every wire that was coming in from the driver door. Best part is i look in the loom between the door and the fender and there is no green/red or black/wht wire at all. Im lost in what to do.
Second thing is i said screw the door lock, ill do that another day. So i take the seering colum apart and there is no room for the ring off the bypass to wrap arounf the key cylinder.
Has anyone every done one that can pass some advice over this way?
Old Oct 6, 2009 | 09:39 PM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 2003 Honda Odyssey remote start/alarm install help
Its there. I did one about a month ago. Green plug with 6 wires. Test each wire while triggering the door locks. Also use a express kit for the bypass. Its will give a cleaner install.
Oyea, don't go for the sliding door one press to open from the remote. Its a pia to do!
Old Oct 7, 2009 | 03:02 AM
laziebun's Avatar
well i found the door lock its on the pass side in a 20 pin connector. what a express kit? and the sliding door i was going to use relay for that
Old Oct 7, 2009 | 03:53 AM
laziebun's Avatar
thought i post this just incase someone in the furture runs into the same issue i just had. I got this off another forum. It seem like only the EX models are the only ones with it on the pass side. There is no 6 pin plug on the EX on the driver side.
2003 Honda Odyssey DirectWire 2.0 Vehicle Information
All Products
Item Wire Color Polarity Wire Location
12 Volts white + ignition harness
Starter black/white + ignition harness
Ignition black/yellow + ignition harness
Second Ignition yellow + ignition harness
Accessory white/black + ignition harness
Power Lock black/white - green 6 pin plug
The plug is located at the bottom of the fuse box. On the EX models the power lock wire is black/orange, and the power unlock wire is blue/orange. They are in a green 20 pin plug on the passenger side fuse box.
Power Unlock green/red - green 6 pin plug
Parking Lights (+) red/black + 10 pin plug
Hazards
Headlight blue/red - headlight switch
Door Trigger black/white - domelight on/off switch
Dome Supervision lt. green - domelight on/off switch
Trunk/Hatch Pin common with door trigger
Hood Pin yellow/red - right of steering column
Power Sliding Door (Left) see DirectFax document 1085
Power Sliding Door (Right)
Factory Alarm Disarm blue - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer blue ac tach test connector
The tach test connector is a 2 pin plug above the brake master cylinder.
Speed Sense blue/white 32 pin plug @ PCM
The PCM (Powertrain Control Module) is located in the center console. The VSS is located in a 32 pin plug.
Brake Wire white/black + brake pedal switch
Horn Trigger lt. green/blue - steering column
Wipers blue & blue/yellow - steering column
Left Front Window (Up/Down) red/blue - red/yellow A driver window motor
Right Front Window (Up/Down) blue/white - blue/yellow A RF window switch
Left Rear Window (Up/Down) green/red - green/yellow A LR window switch
Right Rear Window (Up/Down) red/blue - red/yellow A RR window switch
SilverEK96
Audio / Security / Video
Jun 6, 2012 03:54 PM
GsDAteg
Mar 21, 2010 06:14 PM
Odessa
19
Aug 3, 2004 06:37 PM
technine
Aug 22, 2002 10:09 PM
DocYahoo
15
Jul 20, 2002 04:29 PM
