Bad Distributor
Old Oct 5, 2009 | 07:37 AM
spooledex's Avatar
Default Bad Distributor
I have a bad dist. but it's not the Coil cause I swapped it with known good ones. What else inside of it goes bad and how much is it usually. Is it the TDC sensor? There's only like 3 things inside of it... Thanks.
Old Oct 5, 2009 | 09:14 PM
spooledex's Avatar
Default Re: Bad Distributor
bump
Old Oct 6, 2009 | 04:59 AM
v.i.gsr's Avatar
What problems are you having with the car, for you to determine that its the distributor...
Old Oct 6, 2009 | 05:09 AM
v.i.gsr's Avatar
Old Oct 6, 2009 | 05:35 AM
Killer4Sho's Avatar
It also could be the ignitor.
Old Oct 6, 2009 | 07:47 AM
Wrench_Si's Avatar
Take the ignition control module to your nearest O'Rielly's or CSK O'Rielly's store and they will check the ICM for free.
Also check the wires going into the 3 position sensors inside the distributor for cracks in the insulation. Its quite common and will cause intermittent issues.
Old Oct 6, 2009 | 08:54 PM
spooledex's Avatar
Okay, I take a dist.. Off the car and then put a known GOOD one on it and the car Starts. Thus, the dist is bad. I then swap out coils. Both coils are GOOD. what else inside this other dist could go bad. PLease read thanks.
Old Oct 6, 2009 | 08:55 PM
spooledex's Avatar
Oh, wires are GOOD... thanks
spooledex's Avatar
What's the ICM.
Old Oct 7, 2009 | 11:10 AM
dslamed1.6b's Avatar
New User
well if u put a good dist on it and it starts doesnt it tell u right there that that is ur problem buy a new dist
Old Oct 8, 2009 | 06:37 PM
spooledex's Avatar
holy crap.. it's something inside of the dist.. ****ers. It's something besides the coil. WTF.. is this a hard question..
Old Oct 9, 2009 | 03:01 AM
hondamark35's Avatar
your answer is right here^^ please read
Old Oct 10, 2009 | 12:36 AM
KWayRacing's Avatar
THere are only 3 serviceable parts inside some Honda distributors. Rotors, coils, and Ignitors. If you have swapped coils already then most likely the ignitor(Ignition Control Module ICM) is faulty.
Blk00EJ8
Apr 28, 2007 01:27 PM
invisible
Dec 18, 2006 02:47 PM
Tealeg88
May 7, 2006 09:13 AM
Brian_92GSR
May 21, 2002 04:46 PM
