can i use an ls engine harnes in an eg
Old Oct 5, 2009 | 06:36 AM
saingalang's Avatar
New User
Default can i use an ls engine harnes in an eg
what up HT, im not really new, just been lurking around for a while and finally decided to make an account. anyways...
ive got an ls in my eg 4 door. the o2 sensor isnt plugged in because the plug off the harness is over by the distributor and the o2 is down near the cat. im assuming the harness was used off the old d series motor. question is can i use an obd1 harness off an LS and still be able to plug everything up?
Old Oct 5, 2009 | 06:37 AM
littleblue's Avatar
From: On a island w/ only a bridge to leave it, U.S.A
Default Re: can i use an ls engine harnes in an eg
You can get a extension.
Old Oct 5, 2009 | 06:46 AM
saingalang's Avatar
New User
yeah i thought about doin that by goin to the junkyard and cutting the plugs and making my own
Old Oct 5, 2009 | 06:53 AM
Lasky's Avatar
no need to make an extended harness.. i used a stock d series obd 1 vtec harness on my JDM B16 and ran into the same problem your havin so i scooped an o2 wire extender.. there pretty cheap at pwJDM
http://passwordjdm.com/PasswordJDM-O...P1767C360.aspx
theres 2 different lengths so you can get the right one so theres not alot of extra wiring in your bay
gl man
Old Oct 5, 2009 | 06:59 AM
civiceg8boy's Avatar
i did the ls engine swap to my eg 4dr and o2 sensor plugs in fine no need to change the harness..plus no check engine lights
Old Oct 5, 2009 | 07:31 AM
tlarimer's Avatar
To Answer the OP question, yes an LS engine harness will plug right into your eg shock tower plugs. You can use an ls engine harness from a manual or automatic(just have 3 plugs not doing anything in the engine bay)I just finished this swap in my eg6.
Old Oct 5, 2009 | 07:35 AM
94EG8's Avatar
Seagull Management
As long as its from a '94+ Integra you can use the Integra engine harness.
Old Oct 5, 2009 | 05:40 PM
98civdx's Avatar
Master Detailer
Old Oct 6, 2009 | 08:59 AM
Lasky's Avatar
theres no need to go through the hassle of putting a new harness on the motor when his only problem is the fact that he cant plug the o2 wire into the harness.. hence why i gave him the link for an O2 wire extender...
optaire
May 20, 2012 12:48 PM
appelsos
Jul 21, 2011 12:23 AM
killa.eg
Sep 27, 2010 11:40 AM
hefftone79
Aug 11, 2008 09:01 PM
93b20z
Dec 18, 2006 02:49 PM
