I need HELP!
ok so i just bought an eg about a week ago, and i'm not to good at f/f car's... anyway i was driving home with it (94' incase it matters), and it all of a sudden pulled to the left Hard... like it threw me in the next lane, and then when i started slowing down the entire car was shaking, and there was a slight rubbing noise near my passenger tire... now when i hit what ever speed i want and keep it around there it's fine but when i speed up or slow down it shake's way to much, what do you think it could be... if it was a F/R i would say it's a tie rod... but would it be the same case if it's f/f? thanx...
did you check all your suspension connections. have you done a damage assessment yet? if not check lower control arms, ball joints, axles, and bolts. lower ball joints can brake, bolts can snap. jack the car up and take off the front tires. (use jack stands so you can get under it for long periods of time& safety feature as well). your going to have to get under the car to see if there was any damage. after that you can take pics and post them. hope ts nothing to bad.
TravisCadello
Dec 20, 2008 02:25 PM
Turbo E
Sep 3, 2005 07:45 AM
ridestrt
May 18, 2004 09:27 AM
