Classic Hondas All Pre-1988 Hondas.
1988 Honda Accord Clutch Adjustment HELP
Old Oct 4, 2009 | 03:54 PM
gooberguy31's Avatar
Default 1988 Honda Accord Clutch Adjustment HELP
i just purchased a 1988 Honda Accord, and the clutch slips horribly, but i want to adjust the cable before i change the clutch to see if the cable isn't stretched or anything. My question is how do i adjust the Clutch cable on it?
Old Oct 4, 2009 | 04:22 PM
night's Avatar
Default Re: 1988 Honda Accord Clutch Adjustment HELP
there should be a small amount of play when you pull the cable off the adjuster stop rubber on the bracket.
a bit hard to describe...
grab the cable itself and pull it up. spin the adjuster down until when you let go, the arm just falls down. basically you want it to just let pressure off so there is not constant tension on the pressure plate.
Old Oct 4, 2009 | 06:33 PM
swispisti's Avatar
New User
I'm very interested! I would love to find out more.
me too, I need more detailed info
Old Oct 4, 2009 | 07:18 PM
hmm, that sounds like it could help, i was just checking it out and the cable is holding the arm(where it attaches too, don't know very much about cable) very taught, i wonder if this is causing the clutch slippage. I'm kinda hoping that it's not allowing it to totally engage hence the slipping. I'll take pictures as i go so that it can be more help to people with the same problems.
efrex
Nov 5, 2005 06:45 PM
ThaMatrix
Jun 7, 2005 03:15 PM
Slvr_CRX
Dec 13, 2004 10:08 AM
BIGBLOCKEK
Nov 17, 2002 08:01 AM
