Skunk2 Short Throw Shifter
Old Oct 4, 2009 | 03:19 PM
jonnyt1130's Avatar
Default Skunk2 Short Throw Shifter
Has anyone bought a skunk2 short throw? i just broke my b&m one which i thought would never break, and they won't warrenty it because i lost my reciept. I also had a cheap ebay one in it for a couple days after the b&m went, and sure enough that one just broke. Now my question is do the Skunk2 short throws come with the housing to bolt it up because in the pictures they only show the shifter by itself without the housing. This may sound like a dumb question but i'd like to know before i buy one and find out it's just a bare shifter. thanks in advance.
http://www.skunk2.com/mm5/merchant.m...ory_Code=FTSTS
Old Oct 4, 2009 | 06:18 PM
jonnyt1130's Avatar
Default Re: Skunk2 Short Throw Shifter
anyone??
Old Oct 4, 2009 | 06:29 PM
I Love My 4 door's Avatar
when I bought mine it just came with a bare shifter, no housing. That was for my 89 sedan. good luck to ya sounds very annoying
Old Oct 4, 2009 | 06:41 PM
jonnyt1130's Avatar
so what do they expect you to use for a plate or "housing" or w/e they want to call it...? any help is appriciated
Old Oct 4, 2009 | 06:54 PM
johnnyonth3spot's Avatar
WTF are you talking about housing? The shift linkage?
http://www.myhondapartsstore.com/myh...ystemcomp=List All&vinnoT=&trim=&trans=&view=normal
when I bought my skunk2 shifter it came with a bolt 2 nuts 2 washers a aluminum spacer and the shifter thats it.
Old Oct 4, 2009 | 07:10 PM
jonnyt1130's Avatar
nope i meant parts 8,9, and 12..like how the b&m shifter comes together with no assembly required. i've already got my answer on b20vtec thanks though
Old Oct 4, 2009 | 11:08 PM
dcvt16's Avatar
how hard are you shifting? i've had an egay one for years, but i dont shift like a madman..
Old Oct 5, 2009 | 02:40 AM
raz0106's Avatar
should just fit into the original housing shouldnt it?
Old Oct 5, 2009 | 06:09 AM
jonnyt1130's Avatar
my b&m one snapped like a twig gently pulling it out of first into nuetral, and the ebay one also snapped like a twig gently putting it into fifth gear just cruising. i think the weight of the skunk2 shift **** may be a factor in it too.
Old Oct 5, 2009 | 06:32 AM
dephtone's Avatar
It's bound to happen with a short shifter that is aluminum. My STR short shifter broke on me a couple of weeks ago.
OP you just have to remove the 2 bolts on #9 and the shifter comes out, then you place in your n ew shifter like you did with the ebay model. The link you posted don't work, so I am not sure what housing you are talking about, unless they have a picture of a cable shifter, like a K or H series.
Old Oct 5, 2009 | 06:54 AM
Dark_Teg's Avatar
This is the B&M shifer I have which is mounted on a spherical bearing.
http://www.jegs.com/i/B&M/130/45074/10002/-1?CT=999
If you broke this shifter which is made of billet 303S stainless steel I want to see a picture of you. I am 6ft 235lbs bench press 370 lbs and I couldnt break this shifter if I tried.
Old Oct 5, 2009 | 07:30 AM
jonnyt1130's Avatar
im not a big guy im 6ft 160lbs..ill take a picture later to show you it broke
Old Oct 5, 2009 | 07:47 AM
Dark_Teg's Avatar
Thats crazy,maybe yours was defective.
Old Oct 5, 2009 | 07:59 AM
.Manny.'s Avatar
Touching My Member
try to find an oem integra shifter. a lot cheaper and the throw is perfect!
Old Oct 5, 2009 | 08:53 AM
dacrxguy's Avatar
that is what i am saying especially since he broke two within a couple of days
Old Oct 6, 2009 | 07:21 AM
patrickd_21's Avatar
Buy a TWM short shifter...I've shifter the CRAP outta mine and never a problem...You get what you pay for
jonnyt1130
Transmission & Drivetrain
Oct 6, 2009 07:14 AM
Akavietboy201
May 1, 2009 11:01 PM
Mr. Giggles
Aug 12, 2006 05:49 PM
wowowee
16
Jul 6, 2005 11:13 AM
Can'tCatchMe
Jun 27, 2004 01:27 PM
