SRS Light
hi, my SRS light is on, it came on when i took out the o'meter dash to change the lights that were blown and when i installed it back i notice that the SRS light never went off, i have a 2000 accord V6 sedan and i just want to know what do i need to do to get it to go off
ok i heard it might be a comp located at gas pedal to the right under carpet conneted to yellow wire being faulty or a seat belt sensor being faulty. Really don't know how to test to be right both seem to be expensive fix,but what about the brake light too. weird
If you just want the light to go off, you can try holding down the 'select reset' button while the car is off and start the engine without letting go. It works for the maintenance light, I know that not sure about srs but you can try!
You can not turn off the SRS lamp until the fault [problem] has been repaired. So long as there is a problem and the lamp is on, the SRS [aka airbag system] is disabled and will not work in the event of a crash.
If you did not blow a fuse, I wonder, did you remove the steering wheel [and thereby the driver's airbag] to R&R the instrument cluster? If so, perhaps you did not get everything in the steering wheel assembly wired back up correctly.
To EJFromWestBay, who asked where the fuses are. DUH, give me a clue dude. Year, model and engine please.
Chaz
Last edited by chaztuna; Mar 28, 2011 at 06:06 PM. Reason: Added question about steering wheel removal
Chaz
thanks chaz tuna its a 2000 ex accord 4 cyl 2.3l no accident no taking off of steering wheel i could check all fuses which i will do tomorrow where you said , but for future reference when i am reading on a computer or a book when it tells me to check fuse #7 if there are 8 fuses and 2 columns 4 rows would i assume #7 would be column 1 row 4.
at least i learned to give a good description of my car on forumns i am not really big on forumns
Mitchell says there is a SRS Memory Erase Signal (MES) Connector below the left side of the dash, above the left kick panel but I can't remember exactly where it was or what it looked like. All's I remember is when mine was on I had to jump a yellow connector down there. Sorry i couldn't be of more help. Good luck.
EJ,
No, I don't think you have to worry about anything when doing what was suggested. FYI, I'm a professional mechanic with my own shop. I own a Snap On scanner, so I rarely have to resort to this sort of thing. [It's SO much easier just to hook up the scanner and erase the codes :-) ]
If it appears that the light stayed on, it means you have a hard [ aka constant] problem. A soft code means a fault that is intermittent. A hard code means a problem that is constant. Often, you will clear a code and it will not come back on. Other times, you will clear the code and it will either come right back on, or will come back on within 1 or 2 ignition cycles [times you turned the car on and off]
Regarding the numbering of the fuse box. What you suggest would seem logical and intuitive. Ah, if only the manufacturers thought that way. Generally, if you use a flash light and look carefully on both the legend on the cover to the fuse box and the fuse box itself [look at the black plastic next to where the fuse goes in] you should see some very small numbers for the fuses. They don't want to make it easy for you. Their aim is to make you take it to the dealer! :-(
Chaz
Chaz
EJ,
Chaz
Chaz
To the poster that said the SRS light is on after instrument panel bulb replacement---Did you plug alll connectors back into the cluster particularly the yellow srs connector?
To anyone with SRS issues take your vehicle to a dealer or a reputable import repair shop that has the capabilities of diagnosing SRS complaints. Remember anytime the SRS light is on the SRS system is inoperable greatly compromising your safety in the event of a collision. ALso in 98-02 accords at least 80% of the time the code is seat belt buckle realted which is covered by Honda's lifetime seatbelt warranty so there will be no charge.
A question, then based upon the answer my two cents.
When you pulled the dash, did you happen to pull the steering wheel? If so, (the two cents here) I bet the clock spring is toast.
Here is the one on the OPDS system http://www.google.com/url?sa=t&sourc...6yGWw2EhKZVMnw
Note: these are not recalls just warranty extension. As with the service bulletin dealing with the Seat belt buckles the SRS code for a faulty seat belt buckle switch is SRS Code 9-3. I couldn't readily find a link to it.
Honda has a bulletin regarding an illuminated SRS light, but no code found in memory. They advise that you hook up a volt meter to the electrical system, clear the SRS fault code and watch electrical system voltage the instant that the SRS lamp comes back on. They say that a bad voltage regulator, which allows an above normal system voltage, will cause the SRS lamp to come on, without setting a code. Just an FYI
Some of the TSBs [technical service bulletins] can be found online. Others require a subscription to a data service like AllData or Mitchell OnDemand. See
http://www.alldata.com/
http://ondemand5.com/
If you have a mechanic friend, he probably has access to either or both AllData and Mitchell OnDemand
Chaz
Chaz
