Enclosed air filter box for turbo
Old Oct 4, 2009 | 01:20 AM
kenzo42's Avatar
Default Enclosed air filter box for turbo
I understand that w/ N/As, the most power made is from using a filter in an enclosed box, routed to the underside of the car (Mugen intake for ITR).
Does the same apply to a turbocharged engine?
Old Oct 4, 2009 | 05:12 AM
Bailhatch's Avatar
Default Re: Enclosed air filter box for turbo
If you can get air from outside the engine bay it's ideal. having the inlet in a high pressure spot like a foglight hole is even better.
Old Oct 4, 2009 | 06:26 AM
96 GSR-T's Avatar
x2
The cooler the air the better, huge gains can be made with cooler IAT's in a FI app. Just make sure the airbox is large and you have a very large filter or you will be choking the engine up.
Old Oct 4, 2009 | 12:42 PM
1988_96hb's Avatar
would it affect response or "spool" any?
Old Oct 4, 2009 | 12:48 PM
96 GSR-T's Avatar
If it was restrictive it would, and if you used a shitty filter.
dpine
Sep 9, 2008 08:29 AM
odiumred
Jun 22, 2007 11:27 AM
**DOHC HaTcH**
Feb 14, 2006 06:56 AM
toddyosh
Nov 17, 2004 11:08 AM
dip-set
Mar 5, 2003 10:53 AM
