will b18C pass inspection in new jersey?
Old Oct 2, 2009 | 08:14 AM
OBDII Integra's Avatar
Default will b18C pass inspection in new jersey?
whats up guys, I installed a b18C gsr engine (jdm gsr)....still running off my obd II computer, no check engine light or nething, If i bring it through inspection, when they plug it into the OBDII computer and check the data, will they be able to connect with this engine, or will it not show anything?...thanks guys
Old Oct 2, 2009 | 08:27 AM
Spawne32's Avatar
Default Re: will b18C pass inspection in new jersey?
if your car is obd2, then no, i dont think you will make it through with an engine swap
Old Oct 2, 2009 | 08:58 AM
even if theres no check engine light and the car runs fine?....will it fail beacuse of what engine it is or that it wont read the computer?...thanks
Old Oct 2, 2009 | 08:59 AM
JDM 98 GSR's Avatar
if your using a usdm computer you should be fine
Old Oct 2, 2009 | 09:02 AM
yeah its the original computer out of my 2000 gsr motor i used to hvae, theres no conversion harness or nething still factory wiring.
Old Oct 2, 2009 | 09:03 AM
Spawne32's Avatar
well engine swaps are illegal in jersey, theoretically you could get away with it if the tech didnt know what they were doing, sorta like how i got away with HID's a few months ago cus the techs didnt realize i had them.
Old Oct 2, 2009 | 12:04 PM
alrgiht thanks guys, im gonna try my luck and hopefully all goes well..i'll keep u guys updated..thanks again
Shawncs
Mid-Atlantic
Aug 21, 2017 01:09 PM
thunderboy
Jul 5, 2008 06:35 PM
ITRICED
Feb 19, 2008 04:10 PM
Nikos
31
May 6, 2003 01:16 PM
MiraiZ
Jul 21, 2001 02:14 PM
