how to swap engine
Old Jul 4, 2008 | 05:41 PM
thunderboy's Avatar
Default how to swap engine
Hy I have a b18c engine and I will an other engine b18c engine because the mine is broken. Someone can help me?By tell how I can can change the engine what to do??
Old Jul 4, 2008 | 07:47 PM
vtecb18c's Avatar
Default Re: how to swap engine (thunderboy)
it should be a direct bolt in since you already have a gsr
Old Jul 4, 2008 | 09:55 PM
eaz_e's Avatar
Not really I belive you would have to rewire the Vtec again, might actually have to take it to someone who knows how to do it. Also might have some trouble with OBD unless the B18c your getting is frm the excat same year, I no because my B18b needed all rewiring because it was a OBD1 to an OBD2 swap.. My car is a 95 LS with a 97 LS engine only 2 year difference..
Old Jul 5, 2008 | 12:28 PM
spooled-r's Avatar
Default Re: (eaz_e)
yeah if your engine is from a diff year like 96-00 then you will want to use all the stuff off your current engine use your current intake manifold , alternator and so on
Old Jul 5, 2008 | 02:05 PM
KILLAB17VTEC's Avatar
Genetically Gay
Default Re: (spooled-r)
is there a page here that has pics and shows the step on how to takeout a motor?..i need to know where the hanger is?so i can take my motorout..
Old Jul 5, 2008 | 03:05 PM
northemt88's Avatar
the year doesn't matter if you just get a bare short block then transfer over the dizzy and injectors and the vtec solenoid, then it doesn't matter the obd of the engine but you should try to get the same
Old Jul 5, 2008 | 06:35 PM
B18CYAAA's Avatar
Default Re: (northemt88)
Buy a Helm's Manual or search
Honda4LifeB18C
Dec 25, 2016 02:27 PM
Simkin314
Mar 22, 2012 08:10 PM
tk26
Oct 29, 2006 11:28 AM
gsusfreek
Mar 15, 2002 01:13 PM
