B16A rear mount problem.. plz help
Old Oct 1, 2009 | 11:42 PM
CincyCichlids's Avatar
Default B16A rear mount problem.. plz help
Folks,
This is my first post, I am not a noob on forums, but attempting to search I couldn't come up with an answer. I have a 93' hatch with a D15 in it. I purchased a B16a motor JDM from an Integra (1994), and a 99 civic S4C tranny (non LSD). The T mount and driver side motor mount both hook up perfectly. However, I have 3 rear engine motor mounts, the one that fits perfectly on the engine is about 1" too short to reach the mount that is attached to the frame.
Anyway, someone please tell me which mount I need? If you have one laying around, I'll likely buy it.
Thanks!
Old Oct 2, 2009 | 03:58 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: B16A rear mount problem.. plz help
[Deleted]
pvt awol is right, idk wtf I was thinking.
Old Oct 2, 2009 | 10:42 AM
So this is the fix to the issue? This mount looks very similar to the other ones I have..but I'm guessing the Del Sol version is longer so it reaches the back mount?
Old Oct 2, 2009 | 11:03 AM
pvt_awol's Avatar
hold up on that.
What you've gotten a hold of, is an EK b-series rear mount. It's the mount that is used in the '99-'00 si.
What you NEED to get a hold of, is any '94-'01 integra rear mount. (t-bracket if you wanna call it that)
Trust me from experience, this is EXACTLY what is wrong with your swap. The EK mount looks right, but in the car it comes up about an inch short. The DC mount is perfect. Sounds to me like you got the rear mount with the tranny. Am I correct?
Old Oct 2, 2009 | 11:04 AM
pvt_awol's Avatar
once you swap the integra rear mount on, all else will bolt right up.
Old Oct 3, 2009 | 10:53 PM
aem's Avatar
aem
pvt_awol is right you need a integra t bracket
Old Oct 6, 2009 | 11:56 AM
Ok.. so the mount that came off of the B16a motor is from a 94 integra... as that's where the motor came from. It has a "b" stamped on it... I wish there was a site that had all the different mounts and differences.
The issue here is that I'm guessing the rear engine mount needs to be replaced as well? Anyone have one for sale? I have the following T mounts: 93 D15 T mount (stock), 99 SI T mount (was given to me when I got the tranny), and the B16 mount off from an Integra. I guess the question is, where do I get the engine mount and how do I know this is going to work.. it's driving me nuts seeing this car with the front two mounts perfect, and not able to hook anything else up to it b/c I have to pull it out to get the next mount on easily.
Thank you for your help. If you have the part(s) I need please PM me, I'll paypal you it tonight! lol. I'm near Cincinnati if anyone is close.
Old Oct 6, 2009 | 04:21 PM
Again, the rubber stock 93 motor mount that the T mount connects to will NOT work with the 94 Integra T mount correct? I need to find a replacement for that right?
EgOnBoostALLDay
Oct 22, 2008 05:00 PM
1SloNeon
Jan 29, 2008 12:13 PM
hothotpete
Nov 22, 2004 11:12 PM
Sound Streamin'
Sep 18, 2004 05:16 PM
