81 mm pistons
Old Oct 1, 2009 | 09:01 PM
turbo_ls_69's Avatar
Default 81 mm pistons
ok i am looking at rebuilding my motor and came across a good pistons/rods combo from a member on another site. The only problem are the pistons are 81mm instead of 81.5. are there any problems with running these and how would you go about machine the block to fit them? im not resleeving because my goal is 400hp
Old Oct 1, 2009 | 09:12 PM
.Manny.'s Avatar
Touching My Member
Default Re: 81 mm pistons
if your block is 81.5, you need 81.5 pistons
Old Oct 1, 2009 | 09:42 PM
well i know stock bore is 81 mm, but when rebuilding you usually bore over .5 to clean up the cylinder walls. its a b series btw
Old Oct 1, 2009 | 09:48 PM
Schister66's Avatar
Man U FTW
You don't have to overbore 0,5mm but most people do to ensure a clean, round sleeve. Having said that, i'm running an 81mm built bottom end. If you run the block to a machine shop and have them check taper and out-of-round you should know whether or not you need to overbore. If those results come back positive, buy the 81mm pistons...otherwise, overbore and find another deal elsewhere
cluelessmale
May 28, 2007 07:43 PM
b_jamin
Mar 19, 2004 02:55 AM
omahaturbocivic
Dec 3, 2003 01:44 PM
p10hlm
Jan 7, 2003 11:25 PM
Smurfylude
May 1, 2002 04:39 PM
