81 mm pistons
81 mm pistons
ok i am looking at rebuilding my motor and came across a good pistons/rods combo from a member on another site. The only problem are the pistons are 81mm instead of 81.5. are there any problems with running these and how would you go about machine the block to fit them? im not resleeving because my goal is 400hp
Man U FTW
Re: 81 mm pistons
You don't have to overbore 0,5mm but most people do to ensure a clean, round sleeve. Having said that, i'm running an 81mm built bottom end. If you run the block to a machine shop and have them check taper and out-of-round you should know whether or not you need to overbore. If those results come back positive, buy the 81mm pistons...otherwise, overbore and find another deal elsewhere
