CRAZY idle problem...annoying as hell help!
Old Oct 1, 2009 | 01:45 PM
ChrisHinds's Avatar
Default CRAZY idle problem...annoying as hell help!
ok this may be a little confusing but im goin to explain the problem im having to the best of my ability...
i start the car up wen the engine is cold and it idles at 1500..the bounces quickly from 1500 to 1800 up and down CONSTANTLY all i hear is bwa bwa bwa bwa bwa... the car warms up and idles fine then i hold the throttle at 1500 and its back to the bwa bwa bwa....
i unplugged the tps and plugged it bak in and it does the same thing but at 2000 rpm this time? im so lost...could this be a tps issue? changed the iac and still get the same thing! any help would be greatly appreciated! thanks
chris
Old Oct 1, 2009 | 03:20 PM
sanimalp's Avatar
$cat /dev/urandom
Default Re: CRAZY idle problem...annoying as hell help!
fitv or iacv can be the problem.. there are plenty of posts on H-T about what to do for those problems.
Old Oct 1, 2009 | 04:04 PM
ChrisHinds's Avatar
ive cleaned both and replace the iac... i switched the outter 2 wires on the tps and it doesnt do it.. but at open throttle it bogs so i switched them back
Old Oct 1, 2009 | 04:24 PM
.Manny.'s Avatar
Touching My Member
take off the FITV, which is located under the throttle body (I usually take off the whole throttle body) and remove the two small bolts holding the rear cover plate on. Now use a flat head screwdriver and turn the white valve all the way in until it stops. That should solve your problem.
have fun
Old Oct 1, 2009 | 04:59 PM
project91crxsi's Avatar
mine does the same thing and i have yet to figure it out either
Old Oct 1, 2009 | 05:09 PM
.Manny.'s Avatar
Touching My Member
have you tried what i posted right above you?
Old Oct 1, 2009 | 05:17 PM
might help the OP but mine doesnt have a fitv
Old Oct 1, 2009 | 05:22 PM
rondevus's Avatar
Manny - I have the same problem - Replaced the FIT (New) and cleaned IVAC - Problem still exists! I have read all of the other mails - Any other ideas?
Old Oct 1, 2009 | 05:26 PM
.Manny.'s Avatar
Touching My Member
do either of you have vacuum leaks? try adjusting the idle screw all the way in and then backing it out a half turn.
Old Oct 1, 2009 | 05:48 PM
rondevus's Avatar
Checked for vacuum leaks - no obvious ones! Idle screw will not budge, never did!
Old Oct 1, 2009 | 05:56 PM
yea i fixed 2 and still the same problem, OP should answer these questions
Old Oct 1, 2009 | 06:12 PM
ChrisHinds's Avatar
sorry guys just got in from trying to figure this stuff out... no luck.. tomorrow morning i will try manny's post about adjusting the fitv....i have a hunch its something to do with the tps tho
Old Oct 1, 2009 | 11:38 PM
wakaranai's Avatar
Have you checked your coolant level? This can also cause what you are describing.
Buy some carb cleaner and spray it all around the intake manifold area and anywhere you see a vacuum line. If you hit a leak, the RPM's will go up.
When you say that the idle screw won't budge, you mean you can't turn it left or right? Try to get that sucker unstuck and do as .Manny. said. Good luck to you man. Idle problems can be insanely tricky.
Old Oct 2, 2009 | 03:24 AM
yea i think mines tps also, but for some reason i can turn the idle screw all the way open and then just about all the way closed with no difference till i close it then it drops and cuts out
Old Oct 2, 2009 | 09:45 AM
ChrisHinds's Avatar
well i tried adjusting the fitv did nothing... i have no vacume leaks coolants perfect.. i wanna say its the tps... im gonna change it over as soon as i find a new one and see what happens
Old Oct 2, 2009 | 11:05 AM
try adjusting it with an ohmeter
Old Oct 2, 2009 | 11:09 AM
alex22's Avatar
i can fix it for you if you live in the 818 area
Old Oct 2, 2009 | 08:46 PM
ChrisHinds's Avatar
818?? where the hecks that located
import-tooner
Jul 19, 2013 06:39 AM
f22vtec1
16
Mar 4, 2011 09:07 PM
rcjustin
26
Feb 3, 2006 10:37 AM
jbell
Sep 26, 2005 11:04 AM
smkngsr
May 9, 2005 07:06 AM
