whirring noise because of alignment?
Ok I just got my car running and drove it and its making a whirling noise comming from the drive side wheel area. Most of what I read says its a bad wheel bearing, but I do not want to spend $60 without a better idea of what it could be. I have new wheels, tires, engine swap, and coilover conversion.
During the engine swap, I had take the whole break hug assebly off the car (including the upper controll arm) and replace the lower controll arm ball joint. I also had to repair replace an axle boot...all on the driver side witch is where the noise is comming from.
Would you say this is still a wheel bearing problem? Or with all the other modifications, would an alignment problem do this? The noise is only when driving and gets loulder with higher speeds.
Secret Chimp
Feb 9, 2008 01:27 PM
