Front wheel noise.
Front wheel noise.
My son's 2007 Accord EX has a noise coming from the passenger side front wheel when turning to the left. I checked it out on a jack stand it it seemes the CV Joint boot is making a rubbing noise turning the wheel by hand. A road test told me it might be more than that. It sounds like a rubbing noise, but if you roll up the window on that side you can barely here it. Is the CV joint going on that side? The car has a 2.4 24 valve motor and a 5sp trans. with 92 K on it. Is thing something I need to address now, or can wait until it gets worse?
Thanks!
George
Thanks!
George
My Name is Nobody
Re: Front wheel noise.
you could also try and look for debris in the disk area, between the pad and rotor.
vigorhy
03-20-2008 03:54 PM
