Will this header work?
I bought a used d series dc sports 4-2-1 header for my crx with stock d16a6. The thing is the O2 sensor is on the right side which reads the first and fourth (outside two) runners. It seems like most crx headers have the O2 sensor on the left. Will this work or will it get false readings and cause my car to run bad?
Header wrap it and insulate your O2 Wire, or else it's going to burn the **** out of it if it touches the header, other than that it should work as long as it bolts up to your head.
