Radiator fan runs constant not hard wired
Old Sep 30, 2009 | 06:31 PM
RedlineEG's Avatar
Default Radiator fan runs constant not hard wired
Vehicle 93 Honda Civic DX, engine JDM B16A ECU- Hondata P28 with S300,
SInce I swapped motor in my hatch the fan has always run constant, I have changed the thermostat and Fan Control swith, I have replaced the relays in the engine bay fuse box. still runs constat, Trying to fix this issue now that its gtting colder in MD, the A/F raitos are a little off under boost. Does any one have coolant system wiring diagram?
Thanks for any assistance
RedlineEG
Old Oct 1, 2009 | 05:36 AM
RyanA's Avatar
Default Re: Radiator fan runs constant not hard wired
With the key on, engine off, does the fan run? If so, start unplugging things until it turns off. Start with fan switch on T stat housing, then go to relay, ECU, etc. I don't think that the fan control wire on the ECU will actually run your fan but you may want to make sure.
Old Oct 1, 2009 | 12:54 PM
RedlineEG's Avatar
Yes it runs with the key in the on position, I'll try those options tonight,.
and reply thanks
RedlineEG
Old Oct 3, 2009 | 08:59 AM
RedlineEG's Avatar
She shuts off when relay is pulled, so how do I trace out the wiring from the fuse box.
Old Oct 3, 2009 | 09:41 AM
Former User's Avatar
Does the fan still run if you replug the relay and then unplug the 2P connector from the fan switch on the thermostat housing? If so, then there is a short in the wire running between the switch and the relay or the hood fuse box is bad.
Old Oct 3, 2009 | 02:30 PM
RedlineEG's Avatar
Yes if i pull the switch plug off the sensor the fan will still run, does anyone have a wiring diagram i could use to run resistance between the coolant electrical connections.
thanks in advance for all the help and advice
RedlineEG
Old Oct 3, 2009 | 06:17 PM
napa2u
Nov 20, 2015 09:03 AM
krisdog
Jul 28, 2011 12:21 AM
bowdown201
Nov 19, 2008 04:55 PM
aziaticvang
Aug 22, 2007 06:55 PM
harveyy
17
Mar 1, 2006 04:32 AM
