'99 - grinding sound from front on right turn
This is actually for a friend's car that is exactly the same model as mine (99 4cyl LX 4dr). Car has 105k miles. Recently he had been experiencing some kind of a grinding sound from the front, so I took it for a spin to see what's going on and here's what happening -
There is grinding type of sound that seems to be coming from the left front wheel. Its barely noticeable when accelerating, slightly noticeable after coasting for a few moments, a little more noticeable when braking and very noticeable when the steering is turned slightly right. No change in sound when turning left. By 'turn' I don't mean a corner, but even just a slight change in direction like a bend or curve in the road.
So what do you think might be the problem ? Bearing ? Tire ? Brake ?
Thanks for your replies.
If its the bearing, what's a typical fix for it - replace or re-grease ?
I haven't checked the boots properly yet but a quick visual did not indicate any problem. Can a bearing just go out like that ? This is a gently used car.
97civicdx
May 27, 2009 11:36 PM
Tzarinque
10
Oct 18, 2006 11:06 AM
p0oty
Acura TL, RL & ZDX
May 12, 2006 01:48 PM
