gsr spitting oil...PLZ HELP
Old Sep 30, 2009 | 04:26 PM
cubanteg16's Avatar
Default gsr spitting oil...PLZ HELP
Aight everyone i just swapped a gsr motor into my EG...when I go to start it up it turns over and and idles like normal but the thing is after like 2-3 seconds after it turns on oil sprays outta the back of the motor and it looks like it comes from right under the intake manifold...l from between the head and the block, but that would mean head gasket but last time i heard if the gasket breaks it should be coolant that leaks out not oil besides the point the head gasket is new....well please someone help me with this thanks alot Honda-tech
Old Oct 1, 2009 | 12:47 AM
cubanteg16's Avatar
Default Re: gsr spitting oil...PLZ HELP
bump....20 views and no bumps or help
Old Oct 1, 2009 | 05:21 AM
Dogginator's Avatar
Daisy... Daisy...
Check you PCV.
Old Oct 1, 2009 | 07:03 AM
mouab18c1's Avatar
are you sure its not just a loose oil filter?
Old Oct 1, 2009 | 08:16 AM
94db8R's Avatar
it could be that u put the head gasket on backwords . It happen to me once for talking and not paying attention. It was coming out under the intake mani right at the corner between head and block.
Old Oct 1, 2009 | 08:37 AM
808boosted_db8's Avatar
New User
i would check the oil pressure sensor and the oil cooler and oil filter. if it is not coming from there then i would check the head gaskets for any leaks. just clean up the area where the leak is and start it up and watch where the leak is coming from.
Old Oct 1, 2009 | 09:36 AM
mouab18c1's Avatar
if you checked everything then im sure this is your problem...i did this once myself...ahaha funny shizz but you only learn from your mistakes
Old Oct 1, 2009 | 12:39 PM
cubanteg16's Avatar
Thanx everyone for the help...i noe i can always count on HT
Old Oct 1, 2009 | 03:00 PM
95twotoneteg's Avatar
its deffinely head gasket i put mine on wrong once n it did exactly wat yours did
Old Oct 1, 2009 | 03:10 PM
purestreetracer's Avatar
two other things it could be to...my buddies car was doing that too. on his h22 there is freeze plugs in the back of the block..well one wasnt bolted up and it was squirting oil out. or maybe the oil pressure sensor on the back of the block was taken out..but then you would throw a CEL i think.
Old Oct 1, 2009 | 06:17 PM
YourLocalJerk's Avatar
yeap... seems like head gasket
Old Oct 1, 2009 | 10:51 PM
wunfstgsr's Avatar
Loved
Community Favorite
you sure that sounds like the $1.50 gasket behind the oil cooler that goes out all the time that sounds exactly like it look at the front of the motor on left bottom corner of the head and block where the the head gasket comes out there should be a silver stamp on the edge of the headgasket if its there than the head gasket is on right but did you torque the head correctly?
Old Oct 2, 2009 | 12:22 AM
seanbev24's Avatar
Is the oil filter double gasketed, meaning did the old gasket stick to the block when the filter was changed?
Old Oct 2, 2009 | 12:45 AM
94db8R's Avatar
yup u should check for the silver tap right at the corner if u dont see it then its on backwords thats why it spills oil.
Old Oct 2, 2009 | 01:28 AM
95DC2GS-R's Avatar
I would think the car wouldn't run very "normal" if the head gasket was on incorrectly, but I could be wrong. We accidentilly put my friend's HG on wrong and didn't catch it until we were almost done torqueing the head studs down... took the head off, flipped that bad boy over and retorqued. Cometic FTMFW!!! **** still runs lol
scspeed
Apr 18, 2009 01:54 PM
evolute
Mar 7, 2009 03:52 PM
cbabyby
Jan 25, 2007 05:33 PM
SlammedBlackGSR
Oct 26, 2006 06:56 PM
DsVtec2nrHBC
Dec 2, 2004 04:20 PM
