B-Series Throttle Body On D-Series IM ?s
So i got myself a B18 throttle body.[Ls]
I know it bolts up and i can throw it on there but my z6 TB has a FITV and the LS doesnt.
Should i be concerned about this??
Also, z6 MAP sensor isnt physically attached to the TB as to where the LS on is.
Again, should i be concerned with this?
And lastly, the LS TB didnt come with the TPS. Can i put the z6 one on the LS TB?
Any help will be greatly appreciated.
You cant bolt it up to a z6 manifold because of that reason. And you will get no performance boost from running a B18 TB on a D series IM without porting out the D series manifold to support it. And you cant run without a map sensor.
Wow, cuz im a total idiot and didnt know all of that, LOL. i know i have to port my IM. i know i need a map sensor. my question is that will it work though the map sensor is directly bolted onto the b seried throttle body. Because thez6 MAP sensors are bolted to the firewall or fuel filter or somewhere around there
itl work. as long as you have a mapsensor hooked up some how with vaccum going to it.
but i wouldnt bother putn it on though unles it matches the im.
ya yo cant really do it on a Z6 manifold unless you patch the TB for the Map sensor hole. And idk how the car is going to run without a FITV, it think its going to idle low as hell or stall until it warms up.
on my gsr (i know its a dif motor) but i got a new TB that doesnt have the FITV thingy and i bypassed the coolant hose and it runs fine...wen it does run..i hate that car
i think what he saying is he has a ls throttle body on his ported y8 manifold on his d16z6.
and it fit and connected perfectly.....
johnny-blaze maybe spend some of that weed money on micorsoft word.... just a thought.
Well im throwing this out there. He probably has the firewall mounted Map sensor. My old lx had it that way. And i believe the DX does also. Only the z6 has the map on TB. So if he has any of the above models and swapped in a z6 that would explain his issue with the map.
oh snaps.
