B-Series Throttle Body On D-Series IM ?s
So i got myself a B18 throttle body.[Ls]
I know it bolts up and i can throw it on there but my z6 TB has a FITV and the LS doesnt. Should i be concerned about this?? Also, z6 MAP sensor isnt physically attached to the TB as to where the LS on is. Again, should i be concerned with this? And lastly, the LS TB didnt come with the TPS. Can i put the z6 one on the LS TB? Any help will be greatly appreciated. |
Re: B-Series Throttle Body On D-Series IM ?s
someone correct me, but i thought only the y8 im could hold a B series tb...
-Correcting you- lol
you dont need the FITV. so with ur new TB its fine to bypass it. idk about the MAP
:D |
Originally Posted by Crossbreeder
(Post 40131549)
you need the map sensor, without it i believe it'll throw a cel
i want to get a y8 IM as well. but i just got the TB for now. but i wanna make sure it works right, no crazzy idling and all.
no map sensor=bad news. you will throw a CEL and run like poo
You cant bolt it up to a z6 manifold because of that reason. And you will get no performance boost from running a B18 TB on a D series IM without porting out the D series manifold to support it. And you cant run without a map sensor.
Wow, cuz im a total idiot and didnt know all of that, LOL. i know i have to port my IM. i know i need a map sensor. my question is that will it work though the map sensor is directly bolted onto the b seried throttle body. Because thez6 MAP sensors are bolted to the firewall or fuel filter or somewhere around there
itl work. as long as you have a mapsensor hooked up some how with vaccum going to it.
but i wouldnt bother putn it on though unles it matches the im. |
ya yo cant really do it on a Z6 manifold unless you patch the TB for the Map sensor hole. And idk how the car is going to run without a FITV, it think its going to idle low as hell or stall until it warms up.
on my gsr (i know its a dif motor) but i got a new TB that doesnt have the FITV thingy and i bypassed the coolant hose and it runs fine...wen it does run..i hate that car
i have the ls tb on ma bored out y8 on ma d16z6
and it fit nd connected perfectly. |
^ huh:blink:
i think what he saying is he has a ls throttle body on his ported y8 manifold on his d16z6.
and it fit and connected perfectly..... johnny-blaze maybe spend some of that weed money on micorsoft word.... just a thought. |
Originally Posted by 98civdx
(Post 40147037)
yes it will fit fine on a y8 manifold but not a z6 mani because of the location of the map sensor...
Go to the junkyard, get a b series MAP and cut the plug off the harness...
Originally Posted by R666_EK
(Post 40148584)
Originally Posted by Jimster480
(Post 40151388)
all the map sensors are the same that are on the throttle bodies. Actually all the maps might be the same.
No, the Z6 has a map on the IM, i believe its on the back of it.
1 Attachment(s)
(Post 40152077)
1 Attachment(s)
Originally Posted by mortificationrock
(Post 40152460)
Please show me how this is true......
pic is for u mortificationrock :X |
:swords: oh snaps.
my 94dx has the map on the TB. op shouldnt even do this. its a waste of time..realy there isnt any "upgrade" to this |
