Does Burnout Smoke Affect AFR?
Old Sep 30, 2009 | 09:02 AM
E85B18's Avatar
Default Does Burnout Smoke Affect AFR?
Sometimes turbos suck in tire smoke during a large burnout before a race. It’s easiest to see with a front mount turbo. My question is, how much does sucking smoke into your turbo/engine change your AFR and affect your tune? It seems this lack of oxygen could cause problems!?
Old Sep 30, 2009 | 10:10 AM
1992Si's Avatar
Default Re: Does Burnout Smoke Affect AFR?
That air has been replenished with fresh air a number of times before the car is staged and launches.
Now, I can tell you the rubber does coat the inside of the turbo.
Old Sep 30, 2009 | 10:53 AM
96 GSR-T's Avatar
Unless your doing a burnout all the way down the track and magically sucking it all in the inlet while moving 100+mph I dont see an issue...... kind of a no brainer
Old Sep 30, 2009 | 10:58 AM
E85B18's Avatar
Im sure by the time the car launches it has fresh air in the charge pipe, I was just wondering if it affects the engine while under boost during the burnout.
Since no one ever talks about it, I figured it's not an issue. Ive just seen a couple of videos where someone is doing a 3rd gear burnout and a good amount of smoke is getting sucked in by the turbo. Must not be an issue...
DragSource
Feb 23, 2005 12:38 PM
yimmy
Apr 30, 2003 11:36 PM
pub
Mar 26, 2003 01:14 PM
311
Jul 6, 2002 04:22 PM
