Car still overheating
Old Sep 29, 2009 | 08:07 PM
mrfootball420's Avatar
Default Car still overheating
2000 honda civic still overheating after I replaced the water pump, thermostat and radiator. Any Ideas on what to check next? I am at my witts end with this damn thing. Any help or advice would be greatly appreciated.
Old Sep 29, 2009 | 08:14 PM
skaternak's Avatar
Default Re: Car still overheating
is it leaking coolant. did you bleed the cooling system. does your fan turn on when its hot?
Old Sep 29, 2009 | 08:22 PM
Former User's Avatar
Try bleeding the system like this:
This procedure may take 20-30 minutes:
1) Park the car on an inclined driveway with the front end higher than the rear.
2) Push the dash heater lever/**** to MAX heat.
3) Follow the directions in the diagram below
Old Sep 29, 2009 | 08:24 PM
dunkXdrift831's Avatar
did you bleed the system? also check the header hoses.
Old Sep 29, 2009 | 08:26 PM
YourLocalJerk's Avatar
check if its bleeding..
Old Sep 29, 2009 | 08:31 PM
I havent seen any leaks. I did run it with the cap off and the heater on high for about 1/2 hour to bleed it. The fan does turn on sometimes but I went outside to heat it up real good and the fan didnt kick on. It was coming on the other day though. Hmmmmm, what do you think?
Old Sep 29, 2009 | 08:39 PM
Does the engine overheat while idling at a stop or while driving?
Try jumping the 2P connector for the fan switch on the thermostat housing. The fan should now run continuously. Does this prevent the overheating? If so, replace the fan switch.
Old Sep 29, 2009 | 08:47 PM
Ok I went out to the car and heated it up real good and got it up near the Hot and the fan didnt kick on. Then I let it sit for a minute and then rechecked all the connection on the fan itself. Now the fan is kicking on and off and now it wont overheat while I simulate going up a hill by stepping on the break and the gas same time. Also it has overheated both at idle and driving. So you think its a faulty fan switch.
Old Sep 29, 2009 | 08:59 PM
Now that the fan works, take the car on a test drive. If it doesn't overheat, then you are good to go. If it overheats but the fan still works, I think you should bleed the cooling system again as I described in my earlier post.
Old Sep 29, 2009 | 09:04 PM
skaternak's Avatar
i bled it with the car not have the heat on, cause when it is on the fan never comes on and the heat is dispersed from the heater system, so i let it idle and it turns on and the bubbles come up out of the cap, i left the cap off the whole time too.
Old Sep 29, 2009 | 09:08 PM
You can set the heater to MAX without the blower on. All you want is for the coolant to circulate through the heater core so that all of the air can get out of the system.
Old Sep 29, 2009 | 09:13 PM
skaternak's Avatar
so i turn the ***** to hottest, and fan to strongers and press the button on the left of the ac button, and just wait for about 10 mins? do i leave the cap off or on while doing this procedure?
Old Sep 29, 2009 | 09:20 PM
-Raise front end
-Turn the heater control **** or lever to MAX heat. This opens the heater hose valve on the firewall
-Leave the heater-A/C blower fan off
-Top off coolant in radiator and reservoir
-Reinstall radiator cap loosely
-Let engine idle until radiator fan turns on two times
-Top off with coolant again and tighten radiator cap
-Done
Old Sep 29, 2009 | 09:24 PM
skaternak's Avatar
thanks ron, do i have to repeat the procedure, or just do it that one time?
Old Sep 29, 2009 | 09:30 PM
One time should do the trick.
Old Sep 29, 2009 | 09:31 PM
skaternak's Avatar
thumbs up, iono how you make the icon but yeah...
Old Sep 29, 2009 | 09:36 PM
The third step mentions NOT to turn the cabin fan/blower on.
Old Sep 29, 2009 | 09:37 PM
b20vtec turbo's Avatar
i have the same problem to still havent figured it out yet
Old Sep 29, 2009 | 09:40 PM
skaternak's Avatar
yeah i couldnt understand it the first time. thanks a lot, so i've been doing it wrong the whole time?
phoxking
13
Apr 15, 2011 03:47 PM
acchitt
11
Dec 16, 2010 01:09 PM
TurboTeG4
12
Dec 27, 2009 10:20 AM
eg8guy
Nov 2, 2008 12:21 PM
slowassR
Aug 27, 2004 09:37 AM
