It's 50* outside and my heater is broken
Old Sep 29, 2009 | 01:17 PM
sde780's Avatar
Default It's 50* outside and my heater is broken
I turned on my heater for the first time in 4 months and it doesn't work
The hottest is when the car is warmed up, I turn it on, it blows a little hot for 2 seconds then goes to lukewarm air.
I filled up the coolant, noticed that my resevoir was empty. However it was still not blowing hot air. I've had this leak on the passenger side, it's really wet underneath the carpet. Might this have something to do with it? Where is the heater core located? Car doesn't overheat, etc runs just fine.
Old Sep 29, 2009 | 01:21 PM
D16SiHatch's Avatar
Default Re: It's 50* outside and my heater is broken
core is located behind the dash on the passenger side. it sounds like it might be leaking. it's possible that it's clogged also. might explain why its hot at first then gets lukewarm. check the valve that allows coolant into the car to see if it's opening up all the way.
Old Sep 29, 2009 | 01:30 PM
sde780's Avatar
Cool thanks. Where is this valve at? I have a 1991 civic if I haven't mentioned it yet.
Is the heater core hard to get to, big job to replace? Do I need to drain coolant and stuff before replacing?
Old Sep 29, 2009 | 01:35 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Did you fix your car after that girl ram it in the parking lot?
Old Sep 29, 2009 | 01:39 PM
sde780's Avatar
not yet lol. haven't had much time, it's on my list of things to do for the car
Old Sep 29, 2009 | 01:51 PM
sde780's Avatar
both hoses going to the firewall are hot
longer hose is hotter than the short one.
Upper rad hose is hot, lower rad hose cool. That's what I got from checking it right now. Whatever's leaked in my car doesn't seem to be antifreeze though
Old Sep 29, 2009 | 02:08 PM
D16SiHatch's Avatar
unfortunately it is a pain in the dick to replace. you have to drain the coolant and you have to pull the dash out.
valve is located near the firewall above the trans.
with climate control at its hottest setting it should look like this
at its coldest should look like this
Old Sep 29, 2009 | 02:26 PM
StayKrafty's Avatar
If your lower radiator hose is cool, it might be your thermostat.
Old Sep 29, 2009 | 02:42 PM
sde780's Avatar
Well I mean I did just turn the car on, but the upper was really hot already so idk? My car doesn't overheat though, so I don't see how it could be the thermostat
Old Sep 29, 2009 | 02:43 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/heat-not-working-2225295/
Old Sep 29, 2009 | 03:43 PM
sh!ft's Avatar
Who the fack changed my title?!
sucks to be you! LOL
Old Sep 29, 2009 | 03:47 PM
sde780's Avatar
Yeah it's like that at the hottest and coolest positions
Old Sep 29, 2009 | 03:49 PM
sde780's Avatar
Thank you. I've been searching but haven't seen that thread, I'll check the under dash valve
Old Sep 29, 2009 | 03:54 PM
sh!ft's Avatar
its probably something really simple.....well, hopefully it is lol
Old Sep 29, 2009 | 04:04 PM
sde780's Avatar
I really hope it is. I quit my job a week ago so can't really afford another heater core lol
Old Sep 29, 2009 | 06:57 PM
d16efsedan's Avatar
man sounds like the same problem im having.bump to help us figure this out...
2002hondaCivic
Honda Civic (2001 - 2005)
Apr 13, 2018 03:50 AM
ComicConBooBoo
13
Jan 2, 2011 07:01 AM
Ohannon7
Nov 30, 2008 06:08 AM
Nicaraguense13
Jan 21, 2008 04:20 PM
Jet Black
15
Dec 12, 2004 01:57 PM
