Tranny or clutch problem.
Old Sep 29, 2009 | 11:50 AM
turbojohnny's Avatar
Icon6 Tranny or clutch problem.
So i just changed my clutch on a 2000 GSR yesterday and put everything back on. I was going to take it to work today but when i turn on the car i cant shift into gear!! When the car is off i can put it in gear fine. I also tired to let the car roll in gear with the car off and the clutch down, it rolls but not as fast as if it were to be in neutral.
I bleeded the clutch and fill the tranny up with honda MTF ( 2 1/2 quarts) .
I checked the slave and the master cylinder and no leaks.
What else can be the problem?? Please help me??
Old Sep 29, 2009 | 07:16 PM
vladd's Avatar
Default Re: Tranny or clutch problem.
sounds like a problem with the clutch, time to take the tranny off and check your work. my buddy was having this problem in his integra when the clutch went out.
as for the car not rolling as fast in gear as in neutral, that's because in gear the motor's spinning, adding extra resistance. in neutral the motor's not connected to the tranny.
Old Sep 30, 2009 | 09:18 AM
teamjdm239's Avatar
sounds to me like the clutch is not fully engaged. you gotta take it back off and check the pilot bearing...
withemptyeyes
Sep 18, 2007 05:47 PM
TKL
14
Nov 11, 2004 09:27 AM
mchuang
Mar 9, 2004 05:14 AM
tilt
Oct 7, 2002 01:22 PM
phatintegra
Mar 21, 2002 08:46 AM
