H22a ef not getting spark :(
Old Sep 29, 2009 | 10:20 AM
ef_ftw73's Avatar
Default H22a ef not getting spark :(
Any ideas because I'm clueless when it comes to the dirstributor! Will i have to get a new one it can I change out the internals? It's been converted to obd1, I also heard taking of te distributor can throw off the timing? Is this true?
And I've also heard Thad a d series internals could work in he h series internals, any facts on this?
Old Sep 29, 2009 | 10:26 AM
4drEF's Avatar
Keyboard Humorist
Default Re: H22a ef not getting spark :(
All grounds hooked up (not sure then use a jumper cable and hook to '-' battery to one of the ears on the distributor)?
Cap and rotor in good condition?
You could try using a different distributor or replacing internal parts (probably the ignitor has gone bad... maybe the coil - no way to tell), but I suggest you get a repair manual that shows how to troubleshoot the distributor before putting any money into it.
Old Sep 29, 2009 | 10:30 AM
ef_ftw73's Avatar
I checked that all the grounds are connected and I think it's the ignitor, because I had a test light and it's getting power, but I gues I need to go through my chilton Manuel and see what I can do
Old Sep 29, 2009 | 10:34 AM
the boogler's Avatar
check timing belt
Old Sep 29, 2009 | 10:52 AM
93HoDNA's Avatar
failing distributor. Finding parts is gonna be a Bi*&^
I found mine only at http://hondapartsnow.com
by coincidence, they sell all OEM parts, i didnt need USDM i needed JDm parts. But their digram helped me find it. I was WTFFF! =]
try it your self
Old Sep 29, 2009 | 11:02 AM
ef_ftw73's Avatar
try it your self
Thanks man I will do! But I checked the timing and it was fine, but I didn't think the timing would cause it not to spark?
Old Sep 29, 2009 | 09:05 PM
ef_ftw73's Avatar
gonna try tomorrow and see where it gets me
Old Sep 30, 2009 | 09:04 AM
ef_ftw73's Avatar
anyone else heard about the internals"?
Old Sep 30, 2009 | 09:46 AM
90civichbsi's Avatar
i know ignitors are universal between b-d series I've never had experience with h series though
Old Sep 30, 2009 | 10:11 AM
ef_ftw73's Avatar
tHanks for the imput man, but I'm just gonna go the safe route and get a brand new distributor
Old Sep 30, 2009 | 11:35 AM
has the car been running or is this your first try to get it going?
If its been running before what happened when it started going out? (ex: jumping tach, intermittent starting, etc.)
It takes alot longer for the distributor itself to go out and it will normally throw codes if thats the problem. If your not getting codes its more than likely one or some of the internals (ignitor, coil, cap and rotor)
If the car has not been running have your verified the disributor is getting power? maybe wrong wiring on the jumper for obd1
I would check all this before you get a whole new distributor unless your just tired of messing with it. You can buy all the internals from autozone for fairly cheap although I would be sure the part is the problem before spending money on it
Old Sep 30, 2009 | 11:39 AM
and FYI ignitors are the same from b-d-h series. Coils and caps are not. I Just checked
Old Oct 14, 2009 | 11:00 AM
ef_ftw73's Avatar
she lives
Old Oct 14, 2009 | 12:37 PM
4drEF's Avatar
Keyboard Humorist
And you got that crazy long tube header - love the way that thing looks!
Old Nov 23, 2009 | 11:26 AM
ef_ftw73's Avatar
yessir!, its the kidd racing one
BIGPAPAWACK
10
Aug 23, 2010 11:51 AM
EsCo_EsCo
Sep 29, 2008 08:25 AM
torreypjones
Feb 9, 2007 08:24 AM
djcaseanova
Sep 23, 2003 09:38 PM
