Axle keeps popping out, a little help!
Old Sep 29, 2009 | 06:57 AM
Mugen1320's Avatar
Default Axle keeps popping out, a little help!
Hey guys, so i have a h22 swap into my eg civic, the passenger side axle keeps popping out every 2-3 days when i drive the car. I Widened the C clip a little the other day and today it just popped out again. I'm using 90-93 axle integra from Napa auto parts. The Oem one i had before was clicking so i decided to replace it. The OEM axle did not pop out on me once. I work at Napa so i decided to get a brand NEW axle (not a reman), not too sure if the specs on the brand new axles are different from OEM ones or not. I know the remans are the same specs because they just swap out what went wrong in the axle.
Also should there be tranny fluid leaking if the axle is starting to pop out? I noticed yesterday when i looked under my hood down to my axle that my axle was popping out again and the tranny was leaking, should that be happening?
Any info would be great thanks!
Old Sep 29, 2009 | 07:07 AM
shoklid's Avatar
Default Re: Axle keeps popping out, a little help!
well when replacing an axle a lil bit of fluid will come out so that is normal and if ur center nut and axle is on correctly there is no way poss it could just fall out. no hard feelings but it seems u might b intalling it wrong somehow ive nvr had this issue b4
Old Sep 29, 2009 | 07:14 AM
Mugen1320's Avatar
im 100% that im not installing it wrong, ive done plenty of axle replacing before and this is the first time this has happened to me before. I'm sure the axle is on all the way before putting everything back together (axle boot touching the tranny), but when i start driving again and i look under my hood to my axle i see it slipping out again. Again my OEM axle never popped out and now this just started.
Old Sep 29, 2009 | 07:36 AM
RyanA's Avatar
What trans? LSD?
Old Sep 29, 2009 | 07:43 AM
Mugen1320's Avatar
using h23 trans no lsd with the 2nd gen hasport mounts. i still dont know how its able to come out, im 100% sure i put it in all the way and tightened down all the bolts... could i possibly use DC axles instead of the 90-93 axles?
Old Sep 29, 2009 | 07:52 AM
jdqcivicp72's Avatar
https://honda-tech.com/forums/hybrid-engine-swaps-18/h22-innovative-mount-kit-axle-issue-92-civic-2613533/
Old Sep 29, 2009 | 08:00 AM
1992Si's Avatar
Have you seated the axle with a few hits with a 5lb hammer ? put a piece of 2x4 over the end of the axle and wack it good with the 5lbs hammer.
Old Sep 29, 2009 | 08:10 AM
Mugen1320's Avatar
not sure what that'll do if i got the axle in all the way already? im sure the axle is in all the way, pushed it, jiggled it in and it seemed to sit fine before i tightened all the bolts. it just seems like it likes to come off when i start to drive.
Old Sep 29, 2009 | 10:29 AM
Mugen1320's Avatar
Any other help?
Old Sep 29, 2009 | 12:35 PM
insanemike24's Avatar
Originally Posted by Mugen1320
Any other help?
you can not use a regular integra axle whether it is a 90-93 or a 94-up the axle will never set in the transmission right you need to have a prelude style imboard housing on it in order for in to properly set in the diff
Old Sep 29, 2009 | 04:33 PM
RyanA's Avatar
Yep. Prelude inner and Integra axle/outer. Straight Teg will not work correctly. To make sure it's in there for good, take a pry bar and gently try to pry it out. If it just slides right out, you have a problem. It should take a good amount of force to get it to pop back out.
Old Oct 3, 2009 | 11:35 PM
aem's Avatar
aem
like insanemike24 said you can use those axles you need the prelude inner you need a hybird swap axle or hassport buy them off ebay there like 200 with shipping and theres nothing to worry about there brand new
http://cgi.ebay.com/ebaymotors/Honda...Q5fAccessories
all-mtr-teg
Jan 19, 2010 08:32 AM
Mugen1320
Transmission & Drivetrain
Sep 29, 2009 12:40 PM
stockb18c
12
Apr 6, 2009 01:51 PM
The Dirty EJ1
Sep 3, 2007 04:34 PM
GSpeedR
Aug 11, 2002 03:06 PM
