DEPO '92-'95 & '96-'98 HONDA CIVIC FOGS
Old Sep 28, 2009 | 10:29 PM
ricehead's Avatar
Default DEPO '92-'95 & '96-'98 HONDA CIVIC FOGS
Hey guys, I've seen people use these large fog lights on their accords.
my question is:
Are the Wiring Harness the same too? or at least until the switch? (because obviously the switch is different.)
the reason im asking is because im using the Accord SE fog harness on my CD5 and it messed up the timing on my turning signal and how my lights work (it's plugged into the bottom of the under hood fuse box instead of under dash fuse box). so I'm looking for a good set of OEM or close to OEM wire harness for my lights instead, to get it working correctly.
I've tried to hook up the Universal Harness but it comes with it's own switch and I wanted to use the OEM switch. plus, im not to good with wiring so i just wanna stop all of my headaches and find something that's plug and play.
also, i've learned that the smaller fog lights for the 92-95 2dr civic are the same as the accord 94-95, just different bracket. does anyone know if the harness for this set is the same as the CD accord as well?
i already have half of the OEM harness for under the dash, i just don't have the half that leads to the front bumper...though i don't mind buying the entire harness if i had too....
I know this entire thread my be silly but i'm just trying to find a way to save some bucks since the civic fog lights and harness are so much more abundant than our CD accords and a lot cheaper too.
Thanks guys.
Old Sep 29, 2009 | 06:42 AM
TheMuffinMan's Avatar
He knows where you live!
Default Re: DEPO '92-'95 & '96-'98 HONDA CIVIC FOGS
I will say, if you're looking at the DEPO setups the harnesses are quite different from OEM (if that's what you have in the dash already) Most likely the harness between DEPO Accord and DEPO Civic though are the same.
CHAMPwhteEK
Apr 3, 2009 02:13 PM
JdmB18C667
Jan 24, 2009 09:37 AM
RIZOBIZERT
Honda Civic (2001 - 2005)
Dec 1, 2007 05:13 AM
Matty.
14
Jan 2, 2006 03:49 PM
hYbRiD EeEkAy
Feb 2, 2004 04:29 AM
