maxbore b16 throttle body be enough for this setup???
ok do you think a stock b16 tb done by maxbore with a 64mm bore will be enough for my setup or should i get a 68mm after market tb??? i will be tuning this motor on crome with a rev limit around the 9,500 rpm neighborhood hoping to make around 190 hp.
here is my setup:
motor is jdm b16a
skunk2 intake manifold
Crower cams stage 2
Crower valves
Crower springs
Crower retainers
Crower rods
SRP pistons (with this whole setup to be at 11:1 cr)
Skunk2 pro series cam gears
Micropolish crankshaft
Type r oil pump
Block guard for higher rpm's
besides the parts listed above the rest is all oem parts from the local honda dealer
here is my setup:
motor is jdm b16a
Crower cams stage 2
Crower valves
Crower springs
Crower retainers
Crower rods
Type r oil pump
i used this one on my B16A with great success... great price too!!!
its tapered for a Venturi affect*** 68mm down to 65mm
http://www.optionsauto.com/prodinfo.asp?number=PP-69605
You'll be fine with that TB.
BTW, how high in the rpm range your motor makes power should dictate where your rev limit should be set
yeah i know that. only tuning the motor will tell where the rpm limits will be set at. i know my motor is built to handle up to 9,500 rpm but if it stops making power before that then that is where the rev limit will be set at.
mynameizstitch
Oct 6, 2009 04:12 PM
mynameizstitch
Sep 29, 2009 02:45 AM
mynameizstitch
Sep 23, 2009 08:35 AM
