Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
bad tranny?
Old Sep 28, 2009 | 08:44 AM
01em2slvr's Avatar
Default bad tranny?
hey everyone... im new here. names ethan. i took over my buddy's account cuz he sold his 01 civic. i have an 02 ex and was curious. when i drive my car on regular acceleration and when i down shift there is mad rattling going on. also when i step on the clutch the rattling goes away but i here a hissing sound as if something is spinning. it slowly stops. my question is if my tranny is going out?
Old Sep 28, 2009 | 09:00 AM
maramaralula's Avatar
Default Re: bad tranny?
where does the mad rattling sound comes from you think?? front left of front right??
also do the rattling sound appears as soon as you release the clutch??
Old Sep 28, 2009 | 09:07 AM
01em2slvr's Avatar
ya as soon as i release the clutch. and when i open the hood it comes from the tranny area.
Old Sep 29, 2009 | 09:46 PM
utn's Avatar
utn
Could be a bearing or several bearings in the transmission that are worn out. Could maybe be your pilot bearing too. Check the fluid level in your transmission, I killed a tranny by running it with about 1/2 full of oil for an extended period of time :\. Sounded like there was a fist full of gravel inside there.
Old Sep 30, 2009 | 08:39 AM
01em2slvr's Avatar
how do you check the tranny oil? i was told before it could be the throw out bearing. i was planning on getting a exedy stage 1 clutch kit.. would that fix it?
Old Sep 30, 2009 | 05:42 PM
utn's Avatar
utn
If your problem is the throw out bearing then your transmission would make noise mostly only when the clutch pedal is pressed to the floor. And if that is the only problem, it would be fixed by installing a clutch kit, assuming it comes with a new throw out bearing (which they do).
To check the fluid level you need to remove the fill plug on the transmission, its on the passenger side of the car behind the wheel. It requires a 1/2 inch drive to remove it. If a little bit of oil starts flowing out when you take the plug off you should be fine, but if it only drips out a little bit then stops quickly, it might be low. Only way to be positive its full is to try filling it more until it flows back out the hole.
This should help explain more and aid in your diagnosis. http://www.civicforums.com/forums/36...save-some.html
This is an image of where your fill plug should be. (The closest round thing with a square in the middle)
Old Oct 23, 2009 | 09:37 PM
01em2slvr's Avatar
well we will see what happens on tues when i drive her home. the clutch went out on me today so im thinkin it was the throw-out bearing.
88 EF Hatch
Oct 4, 2009 05:27 PM
civic_coupe_585
May 19, 2008 05:57 PM
hmtcrxsir
Nov 7, 2007 05:07 AM
Dyzee
11
Jul 17, 2004 04:45 PM
ILOVEGIRLS
Feb 25, 2002 04:10 PM
