JDM H22 egr problems
Old Aug 28, 2002 | 10:55 AM
mattEX-R's Avatar
Default JDM H22 egr problems
i've had my 94 accord/H22 hybrid for about a week now. A common problem has come up that i haven't been able to solve or find a definitive answer for. I have a jdm p13 ECU that triggers the EGR lift valve when starting the motor, which pain in the *** as it is, creates vacuum at idle and creates a horrible and erratic idle, though most of the time just dies. So, i run the car with the EGR lines disconnected. This works beautifully for about 5-20 minutes, sometimes less. You guessed it, the CEL comes on and i'm in safety mode. Removing the a11 pin simply enables safemode instantly. The ECU must be fooled into thinking it's functioning, If anybody is this Godly on the subject or ANY kind of solution, it would be tremendously appreciated.
thanks
Old Aug 28, 2002 | 11:02 AM
Spade's Avatar
Default Re: JDM H22 egr problems (mattEX-R)
Is the egr removable?
I had/have this problem with my IACV and I simply put a piece of aluminum between it and the intake manifold....ECU still thinks it works but I have it blocked off.
Old Aug 28, 2002 | 11:28 AM
sgT's Avatar
sgT
you could always get a 94-95 p72 ecu chipped with h22a maps.
Old Aug 28, 2002 | 11:49 AM
mattEX-R's Avatar
Default Re: JDM H22 egr problems (sgT)
alright, thanks guys, will try
is a p72 a better ECU than stock, and where can they be bought?
thanks again
Old Aug 28, 2002 | 11:51 AM
sgT's Avatar
sgT
p72 doesnt have egr control. get it from a junkyard 94-95 GSR
Old Aug 28, 2002 | 11:56 AM
Mikey3000's Avatar
to keep your p13 ecu: take the egr valve off and block the hole in the intake manifold gasket with something (or buy the hondata IM gasket). that's all there is to it. you shouldn't get an idle problem with it taken off (i don't). the CEL that will come on ~10 minutes into driving doesn't matter. that doesn't put it into safe mode or limp mode or whatever it's called.
Old Aug 28, 2002 | 11:57 AM
mattEX-R's Avatar
Default Re: JDM H22 egr problems (Spade)
spade: does the IACV trick you speak of have to do with the EGR indirectly?
732xghost
Nov 8, 2007 03:38 PM
Terrible One
Apr 6, 2006 04:51 PM
jayisnameless
Jan 24, 2004 04:34 PM
