Valves too tight?
Old Sep 27, 2009 | 04:33 PM
88crxvtec's Avatar
Default Valves too tight?
I recently adjusted my valves, when i was finished there was NO tapping anymore. I have omni springs and retainers and supertech valves with GSR cams. There is no valve noise at all but I am wondering is that too tight? I plan on pulling the valve cover tomorrow when it's cold again and checking it out, but I wanted an opinion.
Old Sep 27, 2009 | 06:35 PM
Scott_Tucker's Avatar
Default Re: Valves too tight?
No tapping is what you want to why does it worry you? Did you adjust lash to the spec for the GSR cams?
Old Sep 27, 2009 | 06:42 PM
88crxvtec's Avatar
Just most Honda's I hear have the tapping, lol
Old Sep 27, 2009 | 06:53 PM
Scudweiser's Avatar
the tapping you hear on most hondas might be the lost motion assemblies. mine are tapping pretty loud even after a valve adjustment. boo.
Old Sep 27, 2009 | 09:17 PM
It is possible they are too tight, but properly adjusted valves don't make noise. Did you adjust the valves to the GSR specs or to the specs on your engine. Remember, valve lash specs are cam specific only. So if you use different cams they need to be adjusted to the specs for the cams.
Old Sep 28, 2009 | 07:06 AM
EJ1B18c's Avatar
I would re-check if your not sure. Too tight would be noticable it the power output. But just a little bit too much could cause the exhaust valves not to seat/close 100% and possibly over a period of time overheat.
Old Sep 29, 2009 | 11:42 AM
typeRteggyciv's Avatar
i adjusted my valves recently after rebuilding my head and just started hearing a ticking/tapping noise. any clues on to what it is
raverx3m
Dec 10, 2013 01:50 PM
hothondagurl
Oct 23, 2011 03:38 PM
cornhusker
Sep 20, 2003 03:37 PM
06Xrunner
Nov 5, 2002 05:58 PM
