Open header question
i need answers!
im getting new exhaust and im going to take mine off for a week so i can trim up the rear lip(its melted)
my question is, is this safe? will fumes come in the cabin? anything i should know?
thanks luders, hopefully i can get some good answers lol
Going to be stupid loud, fumes will probably come into the cabin, and depending on the state of your engine, you may shoot flames that could melt things under your car...
I started my car with an open header thinking I was going to drive it home, gave 1 little tap of the gas pedal and decided I needed to close my CUTOUT! To add, other than a 2-3whp gain for 2-300rpm at VTEC, there was NO POWER TO BE GAINED!!....Even at 8000rpm WOT!
do you think i should maybe take just the muffler off then? or cut the pipe closer to the back of the car?
my exhaust is only welded no bolts so i cant just take the axleback off
Yes, if you have to run with a portion of the exhaust missing, I would go as far back as you can. At least with the cat and resonator (if you still have one). If you run it without the muffler it will still be loud but somewhat reasonable.
Hey, your car achieved lift off! Lots of us only dream of that
. I'm sure the landing wasn't anything to be dreamed about but rather have nightmares of.
it also depends whats done to your engine most stock engines will be fine running open headers but a modified engine can suffer some serious damage from the lack of back pressure my friend found this out the hard way when his 12.5:1 compression LS vtec spun a bearing for this reason
so if you care about your engine i would say keep as much of your exhaust as you can or just take it off fix your bumper and put it back on
I ran open header for a while when i got my new header because it was a lot shorter than the old one i had and it didnt reach the cat back even with my test pipe extended all the way lol. I had pretty much no low end power, but once it hit about 4000 or so all the power it was making came out of nowhere. Not to mention everytime i drove it, people thought an extremely low flying jet was going by haha
I'm dreading having to do this to make it to the muffler shop to have a custom exhaust built, the tri-y header's collector is too short. Good thing it's only a block or so.
Nothings wrong with running open header at all, Its just obnoxious and you will get sick of it.
To ShayneRizzle Im curious as to how your friend spun a bearing due to no back pressure. My buddy has an ls/v with about the same compression and we take the exhaust off at the track every time because we get better times all day long.
hey 98vtec, nice to see you.
like my sig? how does it feel to be banned? ill be sure to let george know that your back.
as to my exhaust i went ahead and installed my greddy evo2 and didnt worry about running open header. and btw greddy evo2 w a test pipe sounds sick as ****.
When I dynoed the open header it was 99.9% worthless.
