Suspension & Brakes Theory, alignment, spring rates....
Help installing front struts
Old Sep 26, 2009 | 09:14 AM
todd bayliss's Avatar
Default Help installing front struts
I'm not lowering, just replacing a collapsed stock strut with KYB GR2's.
Problem is that they are about an inch too long to get them back into the fork.
Any suggestions before I start breaking ball joints loose?
Old Sep 26, 2009 | 01:40 PM
kommon_sense's Avatar
Default Re: Help installing front struts
I'm assuming this is an 88-00 civic or 94-01 integra...
Too long to get back into the fork? Sounds like you only removed the strut/spring assembly and left the fork in place?
Save yourself some headache.
- Remove the bolt that connects the fork to the lca.
- Let the fork fall down
- Put strut/spring assembly in place.
- Hand tighten 2 nuts that hold spring/shock to strut tower.
- Attach fork to spring/strut, but don't torque pinch bolt on fork.
Now comes the tricky part, the lca & shock fork holes probably don't line up. You probably have to push down on the brake rotor/hub (possibly even stand on it).
Drive the bolt through the fork/lca holes. I've sometimes used a screwdriver to line the holes up. Snug bolts down. Put a jack under the lca/hub and jack it up to ensure strut is well seated into the fork. Torque all bolts down.
Old Sep 26, 2009 | 06:33 PM
Sorry, should have been more specific. This is on an '07 Accord.
What you described is the way I did it, but when the fork fell down it was still on the bottom of the strut. I was able to wiggle and wrestle it apart, but the new strut was enough longer that it was a no go without pushing harder against the halfshaft than I was comfortable with.
I finally got it in by jabbing a prybar into the coils, then levering them up while using the top of the upper balljoint as a fulcrum. With the coils going up a little and the control arms being pushed down, I finally got it all together.
This was on the passenger side. Weird thing is that when I went to the driver's side, there was like a 1" or more gap between the bolted up strut and the fork.
Anyways, I got it done. Thanks for the prompt reply.
Old Sep 26, 2009 | 09:39 PM
Haven't done a strut job on one of those. I've got an 06TL, so I imagine I'll be in for the same headache somewhere down the road. Glad you got it worked out.
navcc
Apr 8, 2011 03:10 PM
spens 91 Ef
Oct 8, 2008 05:44 AM
alfaaay
Welding / Fabrication
13
Feb 4, 2008 03:29 PM
jimep386
Dec 25, 2006 08:49 PM
FunkDaddyFresh
Mar 23, 2004 06:32 PM
