Busted Engine
So my brother has been borrowing my 97 civic for a while because his truck is a piece. To say the least, he knows absolutely nothing about cars so its safe to assume that he has done nothing for up-keep. So, as he is driving down the interstate today he blows a hole in the exhause side of the block roughly the size of of a pool ball.... I plan on fixing the car and at the same time want to play around with it. I've never pulled an engine much less done a complete rebuild so i thought it would be fun to strip the old block to the core and replace it. I know enough about my car to get by on a day to day basis and do numerous types of repairs but am in no way ex expert. maybe a novice..lol. so anyway the engine is a D16Y8. Nothing fancy and i don't really plan on going to crazy with the rebuild. Probably just going to stay close stock with maybe a few internal upgrades. My question would be if there is anything in specific that i really need to pay close attention to so i don't end up losing the whole engine completely.
buy a repair manual for your car. it will guide you during your engine overhaul. it's pretty straight forward but will be time consuming. remove motor, take off head on old motor, take off tranny, bolt tranny and head to new bottom end (assuming there is no damage to the head), drop motor back in and you're done. of course it's motor detailed than that but like i said the manual will guide you through it.
I already have the and chilton manuals for both my cars. Im pretty familiar with the process and have been doing some research on engine swaps for some time now. I guess more specifically im concerned about disconnecting all of the fuel and A/C lines or anything that might go supernova on me when I start pulling screws and bolts.
follow the steps to clear the fuel system/lines and you'll be fine. Never delt with AC so I can't help you. the most crucial part IMO is putting the head on to the new block and intalling the timing belt correctly...take your time and line everything up correctly. torque every bolt correctly and in the right sequence (headbolts). if you're researching then you're on the right track. nobody personally showed me how to swap/build motors...I learned everything by reading and trial and error.
dzvero
Honda Civic (2006 - 2015)
Apr 1, 2018 10:26 AM
98vtec
Engine Machining & Assembly
65
May 30, 2014 06:55 AM
Alan42978
Jan 16, 2008 06:06 AM
