Crankcase/valve cover venting question
Old Sep 25, 2009 | 08:08 PM
blackstar's Avatar
war all of the time......
Default Crankcase/valve cover venting question
ok so i've read quite a few threads on them both and i'm still a lil confused lol. i'm gonna be running the endyn crankcase breather kit out of the back of the block, now heres my question........if i'm running that, do i really need to vent the valve cover with catch can also?
i dont wanna waste the money on gettin the AN fittings and bungs, plus catch can if i dont really need to run it also. i was gonna run a small UNI filter on the valve cover where the outlet is near the oil cap, any reason to not do that?
oh and if it makes a difference, heres the setup i'll be running........sleeved ls/vtec, 12:1 comp, 85mm bore, twm itbs, rmf compact header, ported head with buddy club 4's
thanx for any and all help!
Old Sep 26, 2009 | 04:46 AM
lohatch's Avatar
Default Re: Crankcase/valve cover venting question
the only way to really know is to put a boost gauge on the engine and see if the crankcase builds positive pressure are higher RPM. you might be able to find a pressure gauge with a small sweep also.
you should be able to temporarily do it off the valvecover nipple. if the boost gauge uses a small plastic line put the 1.8npt fitting on the line and stick it into the hose you have connected to your valvecover
yyyktk1
Aug 10, 2014 04:08 PM
civic-steve-94
10
Jun 12, 2011 05:05 PM
didder
Oct 30, 2008 08:56 PM
Bongnak
Jan 7, 2003 04:44 AM
