throwing code 4 HELP!!!!!
Old Sep 25, 2009 | 07:06 PM
efnborder's Avatar
Default throwing code 4 HELP!!!!!
i just swapped my obd0 dpfi civic to mpfi obd1. the car runs but runs rough and wont go past 3k. and is throwing cel. code 4 and 41. 4 is ckp sensor.(crank positioning) and 41 is o2. i checked the ckp according to the book and tested fine. what happened?? can i bypass it or what can i do to solve it???
Old Sep 27, 2009 | 10:26 AM
efnborder's Avatar
Default Re: throwing code 4 HELP!!!!!
any help would be great!!!!
Old Sep 27, 2009 | 11:41 PM
j-dmek9's Avatar
Have u checked if u connected the map on the tps, or the tps or on the map sensor? or is it timed right?
Old Sep 28, 2009 | 05:59 AM
efnborder's Avatar
ya i tripple checked the timeing and the map and tps are all plugged in. how can i run a test on them to make sure there working proper???
Old Oct 6, 2009 | 09:02 PM
gotboosthatch's Avatar
what ecu are you using? sounds like ur in limp mode also
Old Aug 14, 2010 | 10:19 PM
efnborder's Avatar
Okay I'm out of limp mode but now I'm throwing cyl pos sencer I put in a new dizzy and ecu with no results and the wireing is ran directly into the ecu wtf is going on???
krz6jdm
Feb 21, 2006 01:36 AM
luciffer
Oct 4, 2005 05:44 AM
Gant
May 17, 2005 08:02 AM
Frosty_spl
Feb 12, 2002 02:06 PM
